Trans temp fitting on 4L60E?
Old Mar 19, 2005 | 06:39 PM
SteveC's Avatar
From: Poway, Ca. where GOD and the sun always shines
Thumbs up
Originally Posted by 98A4LS1
Great info/thread and thanks for the link to the install. So, do most mfg's use a 1/8" sender for their trans temp gauges or is this just Autometer? I like digital guages (Cyberdyne possibly) but not sure if the sensor will fit the pressure port you all are talking about.
Lastly, I was thinking about buying a dual or triple gauge A-pillar pod, however, the Summit catalog lists 1997-2002 (T-top). I do not have a T-top car. Will it work/fit a hard top car?
Thanks!!
I have the Cyburdine guages, and they are awsesome, they use a 1/8 NPT fitting, it will go right into the pressure port.
SteveC
Old Mar 20, 2005 | 01:53 AM
98A4LS1's Avatar
Thanks DeepBlueZ and SteveC. That will save me the hazzle of ordering the wrong parts. Nothing worse than having everything apart to install something then realize you got the wrong part, especially a mail order part.
Thanks again for your help!!!
