Finishing up 12bolt install, question..
Old Nov 29, 2001 | 09:56 PM
Sears's Avatar
!Dial-up Director
Default Finishing up 12bolt install, question..
How did you get the sway bar to mount on the axle tubes? I have 3" u clamps, but they don't seem to be long enough. Anybody have a pic?
Thanks,
Justin
[ November 29, 2001: Message edited by: Jsears8 ]</p>
Old Nov 29, 2001 | 10:21 PM
Sears's Avatar
!Dial-up Director
Default Re: Finishing up 12bolt install, question..
Here is a pic of what I am talking about..
Justin
Old Nov 30, 2001 | 07:15 AM
gwj's Avatar
gwj
From: Live Oak, FL - in the woods where the creatures lurk.
I haven't done this install, but if you need longer u-bolts a welding/machine shop should be able to make them. I made them all the time when I worked in a shop.
Measure how much longer you need, including thread length and take an old one with you for a pattern, assuming tube OD is the same.
[ November 30, 2001: Message edited by: gwj ]</p>
Old Nov 30, 2001 | 08:17 AM
onfire's Avatar
Coal Mining Director
J, I just found my older Moser sway bar post and sent it to the top for you. Basically, you take the 3 inch muffler clamps and install it over the axle and put the clamp shell against the axle and put the bar bushing under the clamp...it's easier if you loosen the chassis nut about an inch and tighten it last....you'll also have to angle the ubolts slightly toward the read to miss the diff cover....
Old Nov 30, 2001 | 01:06 PM
Sears's Avatar
!Dial-up Director
Thanks onfire. I'll give that a try. <img src="images/icons/smile.gif" border="0">
Justin
Old Nov 30, 2001 | 01:21 PM
Smoke_ur_5.0's Avatar
I used regular old 3 inch exhaust clamps from Orielly auto parts and bent the sway bar bushing bracket in a vice. Bend the bracket flat and then bend the tabs straight so the bracket now has the longer space between holes to fit the u bolt.
Old Nov 30, 2001 | 01:28 PM
Sears's Avatar
!Dial-up Director
Thanks Mark! That sounds like a good idea. I thought about drilling the hole larger but it didn't look like there was enough material to do so.
Justin
[ November 30, 2001: Message edited by: Jsears8 ]</p>
Old Nov 30, 2001 | 02:31 PM
Big Mike's Avatar
[quote]Originally posted by Smoke_ur_5.0:
<strong>I used regular old 3 inch exhaust clamps from Orielly auto parts and bent the sway bar bushing bracket in a vice. Bend the bracket flat and then bend the tabs straight so the bracket now has the longer space between holes to fit the u bolt.</strong><hr></blockquote>
I did the same exact thing <img src="images/icons/wink.gif" border="0">
Old Dec 3, 2001 | 12:46 AM
02 'Hawk's Avatar
Spohn has some nice looking mounts...I got a set in the garage, powder coated red, that I won't ever use again. I don't think they'd look good on the blue rear end though. WTF were you thinking anyway?
Chris <img src="graemlins/gr_cheers.gif" border="0" alt="[cheers]" />
Old Dec 3, 2001 | 02:28 AM
Jason99T/A's Avatar
I can shift faster than you.
Justin, will the car be ready for the 8th?
Old Dec 3, 2001 | 05:50 PM
AZLS1's Avatar
[quote]Originally posted by 02 'Hawk:
<strong>Spohn has some nice looking mounts...I got a set in the garage, powder coated red, that I won't ever use again. I don't think they'd look good on the blue rear end though. WTF were you thinking anyway?
Chris <img src="graemlins/gr_cheers.gif" border="0" alt="[cheers]" /> </strong><hr></blockquote>
Chris,
I just bought a red torque arm. How much for the SPOHN mounts. I have been driving w/o my sway bar after the Moser 12 bolt install. I am a few hours away in Chandler.
Sterling.
Old Dec 3, 2001 | 10:14 PM
Sears's Avatar
!Dial-up Director
<strong>I don't think they'd look good on the blue rear end though. WTF were you thinking anyway?
I was thinking it would come out darker to match my Silver/blue theme I have. Plus I was <img src="graemlins/gr_chug.gif" border="0" alt="[chug]" /> , so ya know.. <img src="images/icons/wink.gif" border="0">
Jason, I'm cuttin' it close, we will see..
Car or not, I'll be there. <img src="graemlins/gr_judge.gif" border="0" alt="[judgement]" />
[ December 03, 2001: Message edited by: Jsears8 ]</p>
Old Dec 5, 2001 | 06:59 PM
Tim98TA's Avatar
From: From the Bowels of Hell!!! You want some of me bitch?!?!?!
<strong>WTF were you thinking anyway?
I think it's a Hammond thing. Lotsa weirdos over there. LOL
Tim
Old Dec 5, 2001 | 08:58 PM
Sears's Avatar
!Dial-up Director
Weirdos!?! That's putting it lightly. <img src="graemlins/gr_barf.gif" border="0" alt="[barf]" />
Justin <img src="graemlins/gr_jest.gif" border="0" alt="[jester]" />
Old Dec 6, 2001 | 11:10 PM
02 'Hawk's Avatar
I still have the mounts, btw. guy in theread from arizona sent me an email but haven't heard back. still got them.
Chris
Old Dec 6, 2001 | 11:44 PM
Sears's Avatar
!Dial-up Director
Thanks man but I did what Smoke and Big Mike did and it works fine. <img src="graemlins/gr_cheers.gif" border="0" alt="[cheers]" />
Justin
Old Dec 8, 2001 | 02:29 AM
Z06Cam's Avatar
I picked up some 3" muffler clamps from Pep Boys and the u-bolts were plenty long enough... and I have 1LE swaybars.
Glad you got it working Justin.
I've been driving around with my new 12 bolt for a couple days now. So far, its quieter than my 10 bolt was with 4.10's, AND the car definetly hooks harder now... probably because of the extra weight on the rear wheels. These Moser 12 bolts are HEAVY.
