oversized transmission pan? Filter?
I was wondering if most people get a bigger oil pan? 2 or 3 extra quarts? Will either of these cause clearance issues?
The larger ones I have found have been kind of expensive aroud $150. But I found a polished aluminum pan, stock size but with the drain plug and fins for extra cooling for $50, will this be sufficent? I at least want if for the ease of changing oil. Is there a cheap place to get an oversized one?
w/o a cooler looks like big pans would work good to keep it cooler but w/ a cooler wouldnt it be easier to cool smaller amounts of oil?
Also are the aftermarket filters on ebay that cost $7 good?
1" drop vs speed bumps, took it off. Designed
for the car filter but if you grind down the prongs
you can make the truck filter fit nice, which is
better.
TCI chrome steel - the only good thing about it
is the drain plug. Cannot get it to seal.
I have a Silverado pan now I got off Yank's garage
sale, waiting.
