need 2nd opinion on vig converter
Old Mar 30, 2005 | 07:16 PM
96Lt1's Avatar
Default need 2nd opinion on vig converter
I called PI and they told me that a 3200 stall would work for my setup.
Here is a list of mods on my 96 camaro : stock ported Lt1 heads from Meauxs racing ( FMS). custom cam 236/241@50 .577 intake .596 exhaust 113lsa, AFR rev kit, 28 injectors from racetronics / tubro 400 / spohn torque arm/ spohn adjustable lower control arms/ mt dragradials 275/50/15 3.73 gears / 150 nx shot/ 1.6 comp rocker arms /chromoly pushrods/ dynotech optispark/pulleys/qa1s in front . competition eng shocks. heads
Old Mar 30, 2005 | 07:24 PM
AK's WS6's Avatar
That should work just fine for street and track use, but if it's a track only car with mods you have i'd assume you could go into the 4000 range if you are just looking for the best timeslips out of the car.
Old Mar 30, 2005 | 07:53 PM
WJ SOM SS's Avatar
The Vig 3200 is a good sometimes on the street, twice a month to the track converter. 3.73 is a perfect gear for this converter cause it really tightens it up on the street. Looking at your mods, I'd say your rig is not going to be much of a street car, so 4,000 stall is the way I would go with what you've got there. Best wishes. WJ
Old Mar 31, 2005 | 09:22 PM
R_G_LT1's Avatar
anyone else have some ideas !
Old Mar 31, 2005 | 09:26 PM
AK's WS6's Avatar
He needs to tell us what his goal/plans are for the car to get the best answer....
Old Mar 31, 2005 | 10:31 PM
R_G_LT1's Avatar
This is 96lt1 i change my username. my goal for the car is get to the 10.5x to 11.1x on the spray. On the street i will hit the spray after im out a couple of feet, at the track the spray is coming on out the hole ( hopefully the 10 bolt can make some passes) The car will see the track about twice a month. lots of street racing.
Old Apr 2, 2005 | 08:01 PM
R_G_LT1's Avatar
Come on guys I know yall have vig converters out there
Old Apr 2, 2005 | 08:27 PM
rufretic's Avatar
I have a 3800 and its great. Check my sig for mods. I'm not sure if larger stalls work as well for lt1s but I would not be happy with a smaller stall. The 3800 is perfect for my setup. It eats up all my cam surge and drives great. It gets me right into my powerband when I flash it.
Old Apr 2, 2005 | 10:07 PM
SmokingWS6's Avatar
I know our mods/motor are competly different but its a great daily driver, once a week to the track converter.
