350 turbo output shaft
Old Mar 31, 2005 | 08:47 PM
rb6381's Avatar
Default 350 turbo output shaft
My transmission shaft on the output sideto the drive train has play side to side and the seal is leaking slightly. Is there some bearings inside that may be worn, does the back 4 bolt sub assembly on the transmission pull off independently. And does anyone know where I might get a schemtic of the transmission.
