drivability with a converter
Old Apr 2, 2005 | 10:13 AM
00formLs1's Avatar
Default drivability with a converter
whats is it like driving with a 3200-3600 stall, in stop and go traffic and highway?
Old Apr 2, 2005 | 10:20 AM
Yank's Avatar
here is some imfo that might help you
http://www.converter.cc/faq.htm
Old Apr 2, 2005 | 12:19 PM
GregWS6&z28's Avatar
all dependent on the gearing.
Old Apr 2, 2005 | 02:26 PM
RevGTO's Avatar
Pontiacerator
In stop and go traffic, there will be slippage up and down the rpm range, kinda like a manual trans car with a bad clutch. The higher the stall and the higher the rear end gears, the worse it will be. On the highway it will be like stock because it will lock up.
Old Apr 2, 2005 | 03:51 PM
ULTIMATEORANGESS's Avatar
mine is vert streetable.hardly noticeable.
Old Apr 2, 2005 | 05:09 PM
4mula's Avatar
most people who dont know about converters have no clue i have one.
serveral people have driven my car and like the converter i have.
its a tci streetfighter 3000
Old Apr 2, 2005 | 05:48 PM
Dom's Avatar
Dom
My 4200TCI and 4.10s are just fine. The only thing I hate is going 80mph+ on the highway. RPMs get up high, but that's because of the gears not the verter. It doesn't feel loose to me now that I got used to it. Initially it was really weird.
Old Apr 3, 2005 | 08:56 PM
jlrz28's Avatar
10 Second Fun Car
I originally had a vig3200 very good converter then had some tranny problems and something went through the converter and it was way out of wack sent it back and decided to go to a smaller converter so I chose the 2800. This is alot better all around converter than the 3200. Plus they restalled and fixed it for free, great customer service!
Old Apr 4, 2005 | 06:38 AM
Rare96WS6's Avatar
I have a SS3600 and 3.73 gears. The car feels weaker down low due to the sliuppage, but after lockup you could never tell the difference. punch it though and it raps up so fast you bump the rev limiter if you are not careful!
Old Apr 4, 2005 | 09:42 AM
Spdmini's Avatar
I have a yank 3600E with a 2.3 STR, its great around town and locks up btw 35-40. its a great converter.
Old Apr 4, 2005 | 12:57 PM
Red 01SS's Avatar
I have the SS3600 and 3.23's and I dont have any problems. I cant even tell the converter is there.
Old Apr 4, 2005 | 07:36 PM
Mac 2002 SS's Avatar
I have a 3200 vigilante with a tranny cooler and it drives great. I still have stock gears in my car . I just changed my shift firmness and shift rpms for racing and thats it.
Old Apr 4, 2005 | 10:24 PM
BlueSS's Avatar
can anyone tell me what the driveability will be with a vig 3600 and 3:73's...
i have all bolt ons if it matters... TIA
Old Apr 6, 2005 | 04:19 PM
obZidian's Avatar
well, your driveability will, IMO, on your coverters str. The higher that number, teh tighter your converter will be; much like your stock converter. The lower the str, the looser....
basically, if your str is lower you'll have to give more gas to get it going which would kinda suck with MPG, for example.
im still getting used to my converter (ss3600) so im sure there is some else that might help...
good luck!!
Old Apr 6, 2005 | 09:42 PM
BORN2LOSE's Avatar
Believe it or not your exhaust has an affect on looseness also. The louder the exhaust, the more loose it seems because the higher RPM's are more noticable until lockup. Lower gears will make a converter tighter though.
Old Apr 6, 2005 | 11:42 PM
0rion's Avatar
I have a 3500 with 3.23's and it's loose but not bothersome. I just make sure to ease off from the lights if a cop is beside me because my car is pretty loud and the higher RPM's definitely draws more attention I think. It's really no big deal. Basically the only thing you'll really notice is that your RPM's are higher than they used to be.
Old Apr 7, 2005 | 09:22 PM
BlueSS's Avatar
thanx for the replies i think i have an idea of what it might act like now... i'm in wash state and my car is in tex i won't be back south till nov. so i was just trying to figure out more or less how it might affect my driveability i kept thinking i should have gone with a 3200 but by what i've heard i guess i'll be alright cuz of my lower gears thanx again guys
Old Apr 8, 2005 | 03:04 PM
2k1z28's Avatar
hey 4mula,
i was recommended this exact TC by a shop (American Racing Tech) which i plan on doing my cam swap with later. i didn't really ask questions regarding the TC but will this affect my driveability and tranny life??
my car is more street than strip however considering the mods i am planning (cam only swap) this car will be seeing some strip as well. the near future might even call for this to be my daily driver again.
i do plan on adding a tranny cooler which has been recommended many times on this site.
i'm not too familiar so i'm not going to act like i know but my car is a A4, will i have to delete the torque management after the TC install?? i plan on doing the tune however i want to hold off on that till after the cam is in.
how much did your TC install run you??
anyhow, i appreciate any and all info you may have, thanks in advance!!
Old Apr 8, 2005 | 08:38 PM
CamaroCain's Avatar
Yeah at 3k constant rpms, my rear end would whine like crazy, I had a 4400 w/4.10 gears. None of my combos every bothered me on the street. You get use to it.
Lynda
