STR--- what to get..
So in my case what str would you go with on a 3,500-3,800 stall. Any experience you have had, espically guys that changed converters in a similar situation as im in would be great....
What do you have for gears? Are you going with an all new converter? Midwest does free restalls and they'll change your stator for about $175. They have out a new 2.66 stator but if you have 3.23s+ it wouldn't be ideal for hooking up on the street. If you have 2.73s or 3.23s I would stick with a 2.2-2.5str if you want to perform well at the track and on the street. I like my 2.5 str.
Those Nittos should hook fine. I lock my car in second and spin them at about 80mph for a good 5-8 seconds. I come out of the hole between 2,000-3,200rpm depending on track prep. The car has cut low 1.60s in 35* wheather.
Good Luck
