Reverse in a TH400 - use t-brake???
Old Apr 3, 2005 | 10:49 PM
MeanWS6's Avatar
Default Reverse in a TH400 - use t-brake???
i read in another post that some valve body manufactures don't recommend putting the TH400 into reverse to backup, rather put it in neutral and hit the -tbrake to reverse - ANY TRUTH TO THIS
Old Apr 3, 2005 | 11:30 PM
kp's Avatar
kp
http://www.tciauto.com/instructions/221500_inst.htm
ATI is the same way I believe..
Old Apr 4, 2005 | 01:10 AM
red90cobra's Avatar
when you have a t brake the reverse doesn't work with the shifer anyways. it's just gonna be neutral. mines that way. You have to hook it up the transbrake to a switch on your shifter to move the shifter into reverse to even mover the car. I just put it in neutral and hit the trans brake.
Old Apr 4, 2005 | 01:12 AM
red90cobra's Avatar
when i said it won't work putting the shifter in reverse meaning if you put it in reverse the car will not move at all. Will only do if it you have a don't transbrake.
Old Apr 4, 2005 | 08:25 AM
onfire's Avatar
Coal Mining Director
My Rossler rmvb works fine in reverse.....I told him I might not hook the brake up for a while.
Old Apr 4, 2005 | 09:01 AM
john kilgore's Avatar
Default brake
some co. have vb's that back up in rev. and back up in neutral using the brake
Old Apr 4, 2005 | 09:59 AM
MeanWS6's Avatar
ok, so it looks like its better on the trans to put in neutral and hit the button to reverse?
Old Apr 4, 2005 | 11:07 AM
12secSS's Avatar
It really depends on what your trans maker recommends. Ask the company that makes your TB what they recommend.
Old Apr 4, 2005 | 02:33 PM
99'Formula's Avatar
Mine goes into reverse just fine and I also have a transbrake.
Old Apr 4, 2005 | 05:22 PM
B18B1LS1's Avatar
My Rossler uses the regular reverse with the shifter and it has a transbrake also.
