ls1, th400, and ford 9"
Old Apr 4, 2005 | 01:26 PM
Juiced's Avatar
Default ls1, th400, and ford 9"
What Would Be required to Install a t400 w/break on an ls1. are there and adaptor plates required, special input shafts, flex plates, will it use an 40L60e converter or a Standard t-400 converter. Will i be able to retain speedo function (Autometer Hyperlight guage) any info would be great.
Oh one more thing what gears would you guys run with a 30" tire
Old Apr 4, 2005 | 01:32 PM
PHTCBRA's Avatar
The sticky at the top https://ls1tech.com/forums/automatic-transmission/197642-what-would-you-like-see-addressed-th400-faq.html might be a good place to start. HTH
Old Apr 4, 2005 | 01:35 PM
Juiced's Avatar
i've read it.... i guess i'll read it again.
Old Apr 4, 2005 | 01:42 PM
Slow Z28's Avatar
Flexplate from TCI or ATI makes one
Converter can be built a couple different ways, whether for an LS1 specifically or with the use of an adaptor
there is an adaptor plate available, aot of people don't run it though
speedo stuff is listed in the thread at the top
Old Apr 4, 2005 | 01:47 PM
Juiced's Avatar
This is going into a 73 240Z so all parts will be new, thats why i;m kinda confused my vette will stay an m6,
So i Will probably be running a cable driven Speedo directly to the Autometer Guage, and not the pcm.
Old Apr 4, 2005 | 01:50 PM
Juiced's Avatar
Is It possible to lock a t400 converter, if so whats required.
Old Apr 4, 2005 | 02:02 PM
V6 Bird's Avatar
A special pump unit and converter.
Mike
