how do you figure top speed in a stalled TH350?
Yeah but how much difference does the converter slip make? if you calculate it out i should be at 123 mph at 6500 with my 4.10s in top gear. but after you factor in the converter slip how much will it go down? basically i want to be able to do 120 in the 1/4.
Its kinda hard to say how much slippage since it varies from different converters. On mine I am running 26's with 3.73's, hitting 121mph at about 6300rpm's in the 1/4 mile if it helps you any.
Originally Posted by SUX2BU
Thanks man i guess i'll just have to throw it in and see. his is pretty much my first auto i've ever had and am learning everything i can about them. I know EVERYTHING there is to know about the T56 but that could no longer handle what i was going to do.
Srun
