A4 fluid level. How critical?
Old Dec 8, 2001 | 06:20 AM
ONYXSS's Avatar
Default A4 fluid level. How critical?
I recently overfilled my tranny. Took some fluid out, but it still is over the level marked on the dipstick (anyone else have a tough time getting an accurate read on that stick?) So assuming its still a little over, how critical is it? Will a little over hurt anything? Thanks.
Old Dec 8, 2001 | 09:40 AM
Ragtop 99's Avatar
Default Re: A4 fluid level. How critical?
How much over the full mark? Closer to an 1/8" or 1" ?
A little won't matter. An inch over and I would take some out.
Old Dec 8, 2001 | 10:40 AM
Patrick G's Avatar
LS1 Tech Administrator
Agree 100% with Ragtop.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
Old Aug 19, 2005 | 02:38 PM
FungusMungus05's Avatar
Is the only way to drain some fluid out, is to unbolt all of the pan bolts and dropping it?
Old Aug 19, 2005 | 03:01 PM
Ouija's Avatar
Unless you have a really good vaccume that you can hook to the dipstick tube.
Aftermarket Tranny pans often have a drain plug, but if yer stock, dropping the pan a little is the easiest.
Pull all but the four corner bolts. Loosen one corner almost all the way out, then drop the two closest corners a little and it shoudl pour eaisly out for you.
Old Aug 19, 2005 | 03:11 PM
Thanks!
