Downshifting TH400
At 55, my RPM's are 3K. And you will be out of 1st and 2nd so quick. Even from a 30 mph roll you will not need to downshift. you will be in 3rd 99% of the time. Just mash it and go
Chris
Can someone explain me to me how the t-400 with the auto propertys works? If I can downshift that one, I might as well get it. It probably costs more, right?
Chris
David
I am running a Forward Manual VB I built myself.
Steve
You see most RVMB have you remove the forward band and also do not apply the rear band in 1st gear. This is great for the strip but not so great for the street.
Seems everybody runs right out and buys a RMVB even for street use. Not the best way to run a th400 on the street IMHO.
here's what happens when you over spin the direct drum-
https://ls1tech.com/forums/showthread.php?p=1590170
Steve
Not sure, everybody does things differently with the VB's.
There are many mods that can be made to a th400 that effects the shifts.
One nice thing about any manual setup is you can start your burnouts in high gear.
Auto/manual is nice if you don't like shifting. But you need to mess with the govenor weights,modulator setting and hookup the detent switch.
Once it is dialed in the TH400 has real nice auto function.
Steve
And you NEED a 12 volt switch on your T.B. to activate the detent solenoid in the trans.
Steve
I have one in a nova behind a 438 big block. I can go say 110 and put it in first and it'll idle.
Now why is that not good? First off doing this with no front band over runs the direct drum, thats why the one in the picture isn't there, the drum is gone.
Another thing that happens is the drum over runs so fast it slings oil out of the intermediate sprag and this can burn it up due to lack of lube. I've seen that happen once.
You can downshift for those ricer fly bys.
I was going 40 mph once and a girlfriend of mine was in a saturn coming up on me going 80. About a car length away I dropped down from third to first just to pop the rpm up to around 7500, then I hit second and third. She never passed me.
If you drive like this you must really know your car well. I have no rev limiter, that just means you have to know what your rpm is going to do. Sometimes I hit first only for a split second then pull down to second gear.
If I had worse traction doing this could be a real problem.
