Why do i ALWAYS bounce off the revlimiter.
Originally Posted by mimic42100
Brand new tires are on the car. the aboslute highest rating i could buy. those arent the problem. and this is the 2-3 shift, not the 1-2 shift.
Thanks for the help guys =)
nikkev that happened to me. i had to drive 2 hours back in 2nd gear at basicly WOT.
it sucked hardcore. were you reading my past posts?![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
LS6: hmmm. yes acually. i did get new tires. they are the stock ws6 rim size, but the walls may be slightly shorter\taller. this would have that kind of effect?
tomorrow i'm going to get a tranny flush and refill. then goto the strip. =)
Originally Posted by LS6 SS
( sorry about te spelling i am typing with one hand other had is hurt from work)
suuuuuure
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
Thanks for the info. that's my problem then forsure. I Doubt i'm having a 3-4 solinoid go out, or even the gears. 1)The tranny is brand new 2)it only has problems at WOT.
Thanks a lot =)
I have the same problem....I changed the gears to 3.73 and had someone up my rev limiter and correct the speedo with hpt...but I still tag it on the 2-3 shift.....However if I leave it in Drive instead of OD it helps alot..........but i still hit it at the track
My'98-z If you are still hittin the rev limiter come back up here and we can set the rev limiter again
Give me a call and we can set something up. I did another car this weekend and it was like night and day after tuning his car! pm me or something!
![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
