how to make 4l60e full manual shifted
Old Apr 19, 2005 | 02:42 AM
juicedSS's Avatar
Default how to make 4l60e full manual shifted
i wanna know how to make my 4l60e manually shifted. what all do i need?
Old Apr 19, 2005 | 03:05 AM
GT Griller's Avatar
Shift kit : transgo or B&M will do the job.
Old Apr 19, 2005 | 03:07 AM
98whiteT/A's Avatar
hes gotta good question here guys.....help us out
Old Apr 19, 2005 | 04:14 AM
juicedSS's Avatar
my trans was rebuilt bout 6000 miles ago and had shift kit installed with billet servos but its always hittin the rev limiter i dont wanna be havin to hook hp tuners up to it every other week and fix my shift points.
Old Apr 19, 2005 | 12:35 PM
GT Griller's Avatar
If u go with B&M they have 2 different settings one bumps line pressure and u get a frimer shift but if u go with the second one u get full manual control. Same with Transgo they have 3 setttings if u put on the 3rd one u get full manual control.
Old Apr 19, 2005 | 03:33 PM
juicedSS's Avatar
who sells these kits
Old Apr 19, 2005 | 03:34 PM
GT Griller's Avatar
www.jegs.com has both kits but im sure that some of the sponsors like www.thunderacing.com does too.
Old Apr 19, 2005 | 03:53 PM
zippy's Avatar
i don't believe anyone makes a kit at all to make the 4L60E a full manual valve body. manually shifting a stock one can be done. that doesn't make it a full manual. if you program the thing right the first time you won't have to go back in and fix the shift points. the 60E has shown more cases of failure on vehicles that are manually shifted. just make it shift itself like it's meant to.
Old Apr 19, 2005 | 04:16 PM
GT Griller's Avatar
http://www.jegs.com/cgi-bin/ncommerc...87&prmenbr=361
Kits like this will allow for instant shifts so that u can hold the shifter and shift when ever u want yet u will retain regular use when u use D. Now that not "full" manual but its gonna help with what u have a problem with. This way the car shifts right when u want it to and u dont have to wait on the pcm to tell it to.
Old Apr 19, 2005 | 05:58 PM
under_construction's Avatar
Transgo makes a kit to convert to full manual operation, with vacuum modulation. Works as advertised, you can get it here
Best to pair it up with a good aftermarket shifter to prevent overshifting (missing 3rd and getting 4th etc)
Old Apr 20, 2005 | 12:40 AM
zippy's Avatar
there's no reason you can't manually shift it stock. that won't fix the hitting the rev limiter though.
Old Apr 20, 2005 | 09:45 AM
scottyballs's Avatar
the problum with shifting it yourself with the stock trans, is the delay there is a huge delay before it shifts and if you shift where you want it too then your going to bang the limiter... thats why I said screw it and let the trany do the work... you could try shifting at like 5000rpm's then by the time it go's in gear you may be around 6000
Old Apr 20, 2005 | 12:32 PM
GT Griller's Avatar
Witha shift kit that lets u go full manual u wont hit the rev limiter because u get an instant shift. So if u want to shift at 6100 rpm and ur rev limiter is at 6200 then u wont hit cause as soon as u move the shifter the tranny will shift.
If u wanna shift it stock and not hit the rev limiter u shift from 1-2 at 5000rpm and from 2-3 at 4500rpms, this will let the car rev up to about 6000-6100 rpms and shift just before the limiter unless ur limiter is moved from 6200 or ur tranny is slipping u wont hit it.
Old Apr 20, 2005 | 02:39 PM
zippy's Avatar
the rev limiter does not change because you manually shift it.
Old Apr 20, 2005 | 03:07 PM
GT Griller's Avatar
I didn't say it would but what i am saying is that u wont hit it because the car will shift as soon as u want it too. The problem is the lag with a stock tranny where the car stays in geara even after u shift some times it carries to far and hits the rev limiter. With the full manual u can shift just before and not worry about the tranny carrying the gear to far.
Old Apr 20, 2005 | 10:32 PM
zippy's Avatar
even with a stock trans they don't hang. if it has a delay in the shift it's simply because the trans is stock. who would drive something with power and no shift kit/servo change. it's certainly not worth all that effort to shift it when you can just program the computer to shift it where you want it you have to move the rev limiter to shift it past stock anyway. if you're moving the rev limiter, change the shift points while you're in there. for any reason though a real shift kit and servo change is in order.
Old Apr 21, 2005 | 12:42 AM
GT Griller's Avatar
This is what im arguing the fact that this guy doesn't want to reset his shift points. A full manual shift kit will do the job and wont have a problem with hitting the rev limiter.
Old Apr 21, 2005 | 02:49 AM
juicedSS's Avatar
exactly, i want control of my shifts and as i understand by the products u have recomended they will let me do that. these kits are not letting the computer control your shifts and thats what i want. and i havent met many people that have higher stall converters that dont have to mess with their shift points regardless if they have shift kits or not
Old Apr 21, 2005 | 07:04 AM
darrensls1formula's Avatar
No offense intended here but if you want to shift yourself then sell the A4 and buy a M6. A4's were not meant to be manually shifted.
Old Apr 24, 2005 | 03:00 AM
juicedSS's Avatar
u think most people runnin turbo 400`s arent shifting them manually dude
