Which rear end gears for TH400
Old Apr 19, 2005 | 02:00 PM
Juiced346's Avatar
Default Which rear end gears for TH400
What do all the "DRAG ONLY" cars use for their rear end gear ratios?
My car is a Big shot nitrous car that will be spun to approx. 7k rpms.
Preferrably like to the tires I already have (28") would I need to change that also.
Gears in the 9" are 4.30's
Dane
Old Apr 19, 2005 | 02:45 PM
MeanWS6's Avatar
I am running 3.73's
Old Apr 19, 2005 | 03:17 PM
12secSS's Avatar
We are running 4.33s and spin to 6500 rpm on a 29.5" tire.
Old Apr 19, 2005 | 05:03 PM
68maro's Avatar
7 Second Club / STF Veteran
i'd leave the gears alone. unless you plan on trapping over 135mph. if so you could go to a 29" tire which would let you hit 140 with your 7k ceiling. go to http://www.speedworldmotorplex.com/calc.htm
to try out different tire heights and gear ratios till you see what you want.
Old Apr 19, 2005 | 06:40 PM
Juiced346's Avatar
Thats a good question that I dont know the answer to. I have no idea what my car will mph in the 1/4. I would hope to think that it would mph 135 no problem. Looking 2 make near 800rwhp on the bottle.
I would like to leave the 4.30's in there since they are already set up.
Dane
Old Apr 19, 2005 | 07:08 PM
68maro's Avatar
so you're going to make 950 at the flywheel?
Old Apr 19, 2005 | 07:12 PM
Slow Z28's Avatar
i think a step down to a 3.73/3.90 would be good to stay on the 28" tire. I just like allowing myself some extra room. I'm in the same situation with the same gears and going to a 3spd trans as well(TH350).
Chris
Old Apr 19, 2005 | 07:19 PM
Juiced346's Avatar
motor should put down 450 at the wheels and then the motor could see anywhere up to 2 stages equaling 350.
Dane
Old Apr 19, 2005 | 07:25 PM
68maro's Avatar
with that you should only see 650-700 at the wheels. is your 350 estimation based at 350whp of nitrous or just a 350 shot? also should and will are two different things. good luck but i would leave the gears alone till you find out what you're crossing the traps at.
Old Apr 19, 2005 | 08:15 PM
Slow Z28's Avatar
i'm with that cause that's what i had planned, i just think that's the gearing i'm gonna need. but i'm aiming for certain mph. you have to factor in the weight of your vehicle as well for the total "combination"
