cheap 4l60e????
Old Apr 19, 2005 | 03:11 PM
crafty's Avatar
Question cheap 4l60e????
who sales the cheapest 4l60e for a 98 Z-28 putting down about 380-400 hp, but good quality also.. daily driver, not run hard..
Old Apr 20, 2005 | 08:25 PM
ohohsilverado's Avatar
check out flp, one of the sponsors, they want about what a tranny shop was going to charge for a rebuild
Old Apr 21, 2005 | 07:48 AM
peteZ's Avatar
If you've got the time and ambition the cheapest way to build any trans is to do it yourself. The parts (even hi-perf. ones) aren't all that expensive. If you can get a detailed rebuild how-to book and do some research to figure out what parts/tools you need it should be relatively easy.
Usually, about 75% or more of a trans rebuild is labor. For a high performance rebuild/mod, you're also paying for the shop's knowledge of what mods/components work best. With the info in books and the web you should be able to easily build a trans for your power levels.
I'm not a 4L60E expert, but I would guess you could easily buy all the parts you need for <$500.
Old Apr 21, 2005 | 11:17 AM
insaneclown's Avatar
I would just leave it as is. That is not much more HP than stock. I had a 355HP/410lbft motor in front of a stock 700R4 (92 camaro) and it held up just fine, and took it drag and road racing. Recently I tore the tranny all down to put in a shift kit and saw that the clutches were still in great shape so I could have gone a long time without a rebuild.
Unless you need a rebuild I would run it till it pukes and then maybe upgrade a little. But my guess is it will last forever if you're not abusing it.
Old Apr 21, 2005 | 01:12 PM
900DollarZ's Avatar
I beg to differ...
400 is WAY more than stock.
You might try buying the hi-po parts that YOU want (do some homework) and then give them to a reputable shop to install....
