i just have a quick questions that buggin me....why on my 96 a4 does the shift indicator only indicate 2/d/overdrive....while i see other camaros indicating 1/2/d/overdrive????can i not start out and manually shift 1/2/and 2/1 on mine ...also i'm upgrading to a 99 console and i believe that indicates 1/2/d/overdrive...what gives here???on another note would a b&m megaconsole shifter for a 700r4 with a lil mounting work be able to be used on a 4l60e with the linkage and all
You can only go to 2nd gear manually because your rearend has 2.73's in it, EPA stepped in on GM back in the day and said 1st gear selectable would be too loud (rumor I've heard, so im spreading )
Yeah, so they made 1st gear selectable for the 3.23's.
If you want to make 1st selectable, there's a little black stopper, you'll see it when you go to the 97+ console. Just use a dremel, and grind it down a little bit, you'll be able to throw it into 1st.
