shift points
Old Apr 21, 2005 | 05:08 PM
Wu6FiRe's Avatar
Default shift points
hey any u guys know what i should set my shift points at i just installed 3.73's and im bouncing of the rev limiter in 1 2 3 gear need help i have the hyper tech but i dont know how i should set my points anyone know plz let me know
Old Apr 21, 2005 | 08:34 PM
RedHardSupra's Avatar
what's your redline, and where do you wanna shift. also what's the size of your tire? do you have a aftermarket converter?
Old Apr 22, 2005 | 12:48 PM
Wu6FiRe's Avatar
well my redline is 6 but i shift at 55 cause thats were my cam makes its peek power its a stock cam but im fixing to install a 03 zo6 cam and im not sure were its peek power is at and i also have 3.73's would the cam have alot to do with it? i went to hyper tech to check it out but i dont realy understand it
Old Apr 22, 2005 | 01:14 PM
what valvetrain is going in with this z06 cam? i can tell you stuff from experience as z06+3.73 is what i have now
Old Apr 22, 2005 | 03:57 PM
Wu6FiRe's Avatar
all im changing is the cam and springs both Z06
Old Apr 23, 2005 | 12:26 PM
99SSLS1's Avatar
I shift at 6200 in 1st to 2nd and at 6000 from 2nd to 3rd. My rev limit is at 6500. I just dynoed it and I see the peak to but the 1/4 tells me something different. I run my best times shifting where I'm at. With the a4 peak hp isn't all you take into account. The way our trannys are if you shift below 5900-6000 it would slow me down.
Eric
Old Apr 23, 2005 | 06:47 PM
Wu6FiRe's Avatar
hmm ok so what do u think i should do?? how or with what did u set yor points with??
Old Apr 23, 2005 | 07:46 PM
99SSLS1's Avatar
I set them with a hypertech 3 up until last Thursday when I had it tuned. We pulled the hypertech out and flashed the pcm with my shift ponits. We drove it acouple times to get it where I wanted it. The hp3 is the easy way to do it.
My hypertech settings with 3.23 gears are +3 +2 +1 with 50% shift firmness and 6500 rev limit. If you haven't changed anything with the hypertech just make sure shifting around 6000-6200 by plusing or minusing the shift ponits. Then taking the rev limit up till you don't hit it. You should able to make it work without hitting the limit. I'm sure you know most of this stuff but I figured I would just write it all out.
Eric
Old Apr 24, 2005 | 03:12 PM
Wu6FiRe's Avatar
ok..... yeah i got the hypertech also ive got most of what it does installed except the points cause i didint realy know what that setting was for and i noticed that after i installed my gears it starting doing that and even when im just driving it feels weird so i guess you think the best thing to do is wait till i install the new cam or should i go ahead and set them now???
Old Apr 25, 2005 | 06:45 PM
99SSLS1's Avatar
I would set it up now, then get it tuned after the cam. Hitting the rev limit isn't all that good for your motor. Its easy to do just minus your shifts ponits -2 and go try it. Rise the rev limit if you haven't already to 6500. That may cure it be just doing that.
Eric
Old Apr 25, 2005 | 08:09 PM
Wu6FiRe's Avatar
ok.....thanx man ill keep you posted on how it does
