1-2 shift gets worse after tune
Eric
make sure the mph is right- if it is too low and the rpm point is where it should be, the car is going to shift when it hits the last of the 2 thresh-holds (rpm and mph). i've heard this can cause shitty shifting. try upping the mph for the 1-2 shift little by little to see if it gets better or hits the rev limiter.
1644------9------11------33------0
1738------9------16------30.5-----0
1932------10-----23------31------0
2300------11-----31------31------0
2700------13-----49------30------0
3206------14------59------29-----0
3550------17------65------29-----0
4012------24------74------28-----0
4488------30------80------27-----0
4885------34------80------27-----0
5387------38------80------27.5---0
5749------42------80------28-----0
6180------45------80------28.5---0
6488------47------79------29-----0
6790------48------79------29-----0
7044------52------79------29-----0
7216------51------78------29-----0
6599------48------78------6------0
5896------52------76------6.5----0
5314------62------76------27-----0
5205------65------75------27-----0
5214------65------75------27-----0
5205------63------72------27-----0
5180------64------71------27-----0
5130------62------70------27-----0
5068------61------70------27-----0
5001------58------70------27-----0
Just stopped off to get some parts for the car. Heres my take-of(burnout).
Its weird because my TPS wasnt even that high. Does this mean that it didnt go into PE or what? So what do I change so it shifts when it is supposed to? My WOT shift 1-2 is 6800.
