Tranny Temp Gauge Questions...
https://ls1tech.com/forums/showthrea...emp+gauge+pics
Also, what size guage for replacing one of the air vents with a gauge?
It came with everything to install it except 18 gauge wires to run to the sender/power/ground lines.
The sport-comp just uses a light bulb in back that lights up green/red/white, but you could make it light up any color by putting some sort of gel on the bulb.
Also, where do you get into the tranny for the guage to read?
I'm probably going to fashion something up in the center console or the glove box so I can just open it up and look at the gauge when I need to, and keep it shut when I dont want to see it. Looking at the $50ish units from AutoMeter.
as far as the tranny sender. youll see a test port right above the shift linkage under the car and the sender will fit directly into there. Dont forget to use some teflon tape too.
I got the Pro-Comp Ultra Lites and love them. they match my silver gauge overlays perfectly. Here's a pic of my lights i was talking about
you casn also buy 194 LED's to go in there in about any color combination imaginable
http://www.black98.cz28.com/photo6.html
I personally dont think you need one, if you want to check the temps, log into A-TAP or some other scanner tool to periodically check it. Then again, I like the stock look and dont wanty gauges all over the dash.
Oh yeah ... it's mounted in place of the center AC vent.
