What Stall for me?
Old May 20, 2005 | 12:47 PM
LS1 Sounds's Avatar
Originally Posted by nasty99WS6
you cant see how a 3000 verter is more streetable than a 4000?
On an LS1 with a computer controlled lockup converter? I don't see how a tight SS4000 is any less streetable.
Old May 20, 2005 | 01:13 PM
nasty99WS6's Avatar
wouldnt a 4000 need more pedal to move from a stop than a 3000?
Old May 20, 2005 | 01:43 PM
LS1 Sounds's Avatar
A little, yes... That hardly makes it unstreetable though. A 3000 stall requires a lot more pedal than a 1600rpm (stock) stall, yet 3000 is considered small by most. The Yank SS 4000 is reported to feel like most other vendors' 3000 stalls, but I have to admit that I haven't had a chance to drive one yet myself.
I wouldn't even think of getting a stall less than 3500rpm for my car, and I drove 30 miles to work one way in Washington D.C. area traffic. The Vig 3200 wouldn't even be in my car if I didn't buy it that way. It will be replaced with a Yank SS4000 after I finish some more mods. Most people that buy a 2800-3200 stall wish they would have gone higher the first time around. I'm a firm believer in buying the right part the first time around.
The best thing to do though is find somebody in your area that has a stalled A4 and see if they'll take you for a drive. Then there's no room for mistake. For reference, here is a video from inside my car with the Vig 3200 from a while back:
http://www.ls1sounds.com/my_car/SLP-...eak_in-car.wmv
-Chad
Old May 20, 2005 | 02:32 PM
nasty99WS6's Avatar
not trying to steal superman09's thread, but quick question for you ls1sounds, I heard the "ideal" converter for ones car is one that drops you 500 rpms or so below your torque peak. Is that true? The yank tt3000 came with my car as well, but my mods are starting to pile up. I also want a streetable tc, but one that is fit to my mods, know what I mean..sorry again superman09..
Old May 20, 2005 | 05:55 PM
AFTICA's Avatar
-Chad
Count me as one of those people. I've always been ultra conservative with stall converters but found that with lock-up converters I can stand quite a bit more stall because after 37 mph it's a non issue. My 2800 vig has taken me into the 11's and drives like stock but there's a SS4000 on the bench waiting to go in.
Old May 20, 2005 | 06:24 PM
Superman09's Avatar
LS1Tech Sponsor
Ok cool. I just got a PM from a guy at Fuddle Racing. Said i can get a custom stall form him with whatever specs i want for a pretty low price. Any info or feedback on them? Also so I cant decide which stall between 3600-4000. What SRT rating or whatever would be best for me? Thanks. I really want it to be streetable, but be killer o nthe street and track ,lol thanks.
__________________
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
Old May 29, 2005 | 11:49 AM
wrath22's Avatar
my advice cause i was in the same boat as you superman. never put a t.c. in my car before and had no knowledge of one either. so i came here asked like you did and did my research. i have alot more mods than you and i choose t.ci. 3500 w/ a cooler. a cooler is a must do not neglect to get one. temp will be much higher without one so spend some more $ to get one. they are very reasonable to purchase and install. i was very nervous about the change and how it would feel. install date and dyno tune is not till june i will let you know then how it feels. good luck man.
Old May 31, 2005 | 06:41 AM
LS1 Sounds's Avatar
From Yank's FAQ section:
Originally Posted by Yank
Which converter should I choose for my application?
7. Typically, you want to choose a torque converter with a stall speed 500-700 rpms below the engine's torque peak. For example, an engine making peak torque at 4500 rpms, a 3800-4000 converter would give maximum ET. For a quick selector guide, press here. To see chassis dyno results of our different converters, press here.
In choosing your torque converter, understand that there is no one best converter for all situations. A converter that produces very good results at the track may have reduced drivability in town. Key factors are your planned usage, current and future modifications, and drivability. If your primary goal is increased performance at the track, you will want to select from the higher stall converters, 3500 rpm and up. For mostly street driving, you will want to select from the converters with a stall of 3500 rpm or less.
A higher stall converter will be "looser" than a stock converter. Looseness refers to the fact that the converter slips the engine into a higher rpm. The use of higher rpms helps provide greater torque during full throttle acceleration, but it also causes the engine to use higher rpms at part throttle too. Looseness can be demonstrated by comparing the typical in town rpms used by a stock converter and a performance converter. The table below demonstrates the range of looseness.
Stock 1600 1600 - 2000 part throttle rpm range
Thruster 2800 1800 - 2200 part throttle rpm range
SuperYank 3500 2000 - 2500 part throttle rpm range
Pro Thruster 4000/4400 2500 - 3000 part throttle rpm range
The stock converter requires the least amount of throttle input and will accelerate at lower rpms. The Thruster 2800 is nearly as tight as stock, requiring only slightly higher rpms. The SuperYank 3500 is looser. While under light throttle the car can be driven at below 2,000 rpms, most drivers will be using 2,000+ rpm until lock up. Once the converter locks up (typically 35 - 40 mph), the rpms will drop off to the exact same rpms as the stock unit. The 9" Thruster Pro is the loosest, but provides tremendous gains at the track. Note that the rpm range used in the above example was for a car with 3.23 gears. A car with 2.73s would use higher rpms, while 3.73s would require lower rpms.
Looseness is mostly a perception issue. Because the car uses higher rpms, the exhaust note is more pronounced. Cars with loud aftermarket exhausts will definitely notice the increase in exhaust volume, while cars with quiet systems will notice only a small change. Looseness can reduce the feeling of snappy part throttle acceleration. This sensation is primarily due to the fact that a larger throttle input is required. Most people adjust quickly to a looser converter. If you are unsure of whether looseness will be a concern, consider test driving a friend's car before buying a converter.
Old Jun 1, 2005 | 01:36 PM
B T's Avatar
B T
-Chad
Thanks for that little video LS1 Sounds.
I think it has really helped me make my decision on a stall speed/w 2:73's since I don't know anyone that has a higher stall than OEM to test drive.
The one you have looks a little too loose for me on just the street. stop go traffic.
Looks like I should stay right at or below the one your using now.
BTW, are you looking to sell the one in the car now after you get the new one?
If so let me know how much and PM me when you get your new one in and if I haven't already bought one I might still be in the market.
Thanks.
Old Jun 1, 2005 | 02:03 PM
LS1 Sounds's Avatar
Thanks.
Will do! I plan on getting a 4000 stall as soon as I can afford one, which probably won't be any time soon.
Old Jun 1, 2005 | 02:28 PM
Joel_SS's Avatar
My wife has a SS 3600 in her car and yo
u can barley tell it is there.. It is 100% streetable.
Old Jun 1, 2005 | 02:30 PM
  #32
greatskiiiier's Avatar
how much did your gas mileage change going to the 4000
Old Jun 1, 2005 | 02:41 PM
  #33
B T's Avatar
B T
LS1 Sounds and Joel_SS :
What rear gear are you guys using?
Old Jun 1, 2005 | 04:02 PM
  #34
LS1 Sounds's Avatar
3.23 for now... but I plan on changing to a 3.73 or 4.10 if the rear breaks.
Old Jun 1, 2005 | 04:23 PM
  #35
darrensls1formula's Avatar
I would recommend staying in the 3000-3500 stall range for a mostly street car. TCI 3500 is a great all around verter for price and quality. Fuddle racing is still new so I can't really say how quality is yet. But if you got a few bucks to spend then the Yank SS3600 is a nice choice too.
Old Jun 1, 2005 | 05:37 PM
  #36
-Chad
I understand your idea, but for gas mileage stepping from a 2800-3200 to a 4000 is going to bring your gas mileage down 1 or 2 MPG, and your ET only .2 if you're lucky. I don't know if you have a stock cam or not, but with a stock cam the torque is right near its max at 3000RPM, aka you would want a 2800. Unless you go aftermarket with the cam, over 3200 isn't worth the price in gas or product.
Old Jun 2, 2005 | 04:27 PM
  #37
radz282003's Avatar
I have a SS3800, and love it. Yeah, it' s loose. It' s my first, so, to me, it is on the threshold of " drivable." It rips when you get into it though, and my gas mileage hasn' t diminished. It a daily driver, and i do a lot of traffic driving, so this may be around what you may consider to be close to the edge. Just don' t go too small.
Old Jun 12, 2005 | 08:43 PM
  #38
jhelms's Avatar
Great post guys, keep the info coming....
