Here's the problem
Old May 27, 2005 | 03:30 PM
DGEN411's Avatar
Default Here's the problem
This problem just started. At full throttle at around 6000 rpms the car should shift from 1-2 but instead it drops to about 4500 rpms then slowly shifts. The simple answer is the trans is sliping but at low throttle and even 3/4 throttle it shifts perfectly. I dont know if it does it from 2-3 I havent hit the highway yet. Do you think its just the trans slipping or could it be something else?
Old May 27, 2005 | 05:42 PM
Roarin_8's Avatar
What was the last thing that you did to the transmission? I would check there first.
Old May 27, 2005 | 06:21 PM
DGEN411's Avatar
The only thing I did to the Trans was the slp mod and I took that out to see if that was the problem. The fluids full and everything. I never had a problem before.
Old May 27, 2005 | 07:24 PM
Roarin_8's Avatar
How many miles are on that transmission? Did you ever change the fluid and filter before and how long ago was it?
Old May 28, 2005 | 01:25 PM
DGEN411's Avatar
The Trans is old and I'm sure its just wearing out but I thought it was weird that it doesnt slip in any other throttle position.
Old May 28, 2005 | 07:01 PM
Roarin_8's Avatar
I'd say it's time for a rebuild but that is just my opinion. Good luck.
