Help with Stall convert Choice
Old Jun 12, 2005 | 08:20 PM
formulajunky's Avatar
Default Help with Stall convert Choice
Well i got very few runs in friday but heres what i ran
On bottle with 150 dry shot
12.800@112.93 60 was 2.146
Engine was a
13.675@ 101.36
No mods done but bottle and 3.42 gears and i was on BF DR
I"m thinking about shall converter next but not sure what to get with this setup any idea guys my 60ft times sucks any ideas there
Old Jun 12, 2005 | 08:49 PM
Ragtop 99's Avatar
To fix your 60' times, about 3300 - 3800 stall will do the trick.
Your 60' on the bottle sucks. Were you spinning? A progressive controller might help you hook if the 150 shot overpowers the tires. Otherwise cut the spray back to 100 shot and get a dead hook. You may loose a bit of mph but your ET will drop by .5 if you get your 60' into the 1.7s. Better tires will help too.
If you were not spinning, the stall will solve your problems.
Old Jun 12, 2005 | 09:00 PM
Default not to sure
ot sure if i was spinning or not. I pretty sure i wasn't buy a buddy told me i was a little. I'm running Bf Dr and heating them pretty good. Not sure why my 60ft times where so bad Stall would be good What kind of conver should i get any ideas there
Old Jun 13, 2005 | 12:10 PM
Ragtop 99's Avatar
Yank SS3600, TCI 3300, or Vig 2800 would all do the trick. I ran several different Yank converters with good results before I converted the car.
If you go a little bigger, your NA time will improve, but spraying out of the hole will definitely require moving up to ET Streets or Drags.
Old Jun 13, 2005 | 08:56 PM
JZ'sTA's Avatar
I ahree with ragtop.
Your whole time slip sucks NA and on spray.
I would do a Yank converter mayself, or a TCI if your not a Yank fan.
I have always had good/great results with Yank and refuse to switch.
I tried Vig and Midwest before and the Yank kicked their ***.
I haven't used a TCI and hear a lot of good things about them.
