Which cam for a 3000 stall?
Old Jul 10, 2005 | 01:49 PM
blkZ28spt's Avatar
Originally Posted by RevGTO
A guy I know with a 3500 stall went from a 220-114 to a 224-112 and got no increase in performance but had a major loss of in-town driveability.
Something is wrong if going from a 220 to a 224 gained no performance and induced a "major" loss of drivability.
Old Jul 10, 2005 | 10:36 PM
RevGTO's Avatar
Pontiacerator
E.t.'s were the same but he found the choppiness from the tighter LSA made it unpleasant for daily driving. I doubt if the additional duration made much of a difference.
Old Jul 10, 2005 | 10:56 PM
blkZ28spt's Avatar
So basically, he considered lope to be a "major loss of drivability". That's how I'm reading it. Lope does NOTHING to decrease drivability. He may not have liked the lope, but that's not the point. Or am I missing something?
Old Jul 11, 2005 | 05:19 AM
XTrooper's Avatar
Not to mention the fact that "lope" is really only a factor when at idle. My car has a pretty wicked lope and is shaky at idle, but as soon as the motor get a little throttle, it smooths right out. While driving, the car is really no different than if it had the stock cam in it.
Old Jul 11, 2005 | 08:13 PM
RevGTO's Avatar
Pontiacerator
Y'know in thinking about it, maybe I overstated his case ... "major loss of driveability" was my terminology not his, but that was the impression I got from him. Basically, he told me how he switched cams and got no gain but driveability suffered ... I didn't go into detail with him about what it was he didn't like. He is a competent, knowledgeable LS1 guy who has done a lot of cam installs. It was his experience and I passed it along FWIW. We all know driveability is somewhat subjective as is "looseness" with converters.
Old Jul 11, 2005 | 11:19 PM
Firebird84's Avatar
Default wrong
hey man i dont mean to be a bitch but your going about it all wrong pick your cam and then find out what stall is best for that cam. your backwards
Old Jul 11, 2005 | 11:32 PM
blkZ28spt's Avatar
Happens that way all the time. As you can see if you read his sig, he already has the 3k stall converter, so why not decide based on that?
Converter comes before cam and it's hard to pick a cam before you even get a converter and then actually get that same cam (or one very similer in nature) whenever cam swap time comes around.
Old Jul 12, 2005 | 08:46 AM
4mula's Avatar
most guys get a converter before a cam.
Old Jul 12, 2005 | 09:52 AM
XTrooper's Avatar
As long as you end up with a matched setup when you're done, the order you did it in doesn't really matter.
It's true that most A4 guys get the converter first, then the cam, but some do it the other way around. If you choose the right components, the end result should be the same.
Of course, some of us like myself go through two or three cam and converter swaps before we're satisfied!
