down sides of high stall speeds?
Old Jul 8, 2005 | 10:41 AM
FastKat's Avatar
Default down sides of high stall speeds?
With a lockup converter, what are the downsides of having a high stall speed?
Old Jul 8, 2005 | 10:47 AM
Joel_SS's Avatar
none IMHO
Old Jul 8, 2005 | 10:52 AM
FastKat's Avatar
How about for a daily/weekend driver?! If there are no downsides, stock OEM converts would have all high stall speeds!
Originally Posted by Joel_SS
none IMHO
Old Jul 8, 2005 | 10:59 AM
12secSS's Avatar
They build excessive heat. Also, how high are you thinking? For me a high stall is 4500+ and to reach that, you would need a 9.5" core (which could become very inefficient) or use an 8". The 8" won't be able to use a lock up feature.
Old Jul 8, 2005 | 11:08 AM
FastKat's Avatar
Well, I'd like my setup to hit full boost between 3500 and 4000 RPMs, and start building between 2000 and 2500... I am sure I will have to compromise on one of those numbers, but that's what I'm shooting for. I guess my ideal stall would be between 3000 and 4000 then, huh?
Seems to me like if it's stalling at higher speeds, normal daily-driver starts would be soft and mushy, or require excessively high RPM's and be impractical. Do you guys see any of that?
Old Jul 8, 2005 | 11:21 AM
josh99ta's Avatar
Sold The Fun Stuff :(
The higher the stall, the more pedal you're going to have to use and the more RPMs you'll be turning to accelerate from a stop. Once you're at speed you've got lockup so it's no big deal. As long as you have a tranny cooler I dont see heat being a big deal either (it gets mid 90s here in TN and with my 4000 stall and B&M 24gvw cooler I rarely see over 170 degrees in the tranny, maybe 185 if I'm doing alot of stopping and going or WOT runs).
Really the looseness is the only downside I see. The bigger the stall the looser it is. This can be compensated for by gearing and weight reduction. Lighter cars feel tighter and cars with lower gears (numerically higher) feel tighter. My 4000 stall with 3.42 gears in a stock weight T/A (3600-3700) is fairly loose, but not excessive enough to really bother me.
Old Jul 8, 2005 | 02:47 PM
Scotty-Z's Avatar
I agree with you Josh. It's probably just the looseness. I think everyone with a converter, even if it's a 2,800 or 3000, should get a B&M 24,000 cooler. It just makes sense to keep it cooled off as much as possible (within reason). So the heat isn't a problem, but you will get used to it.
Old Jul 9, 2005 | 04:31 AM
K9Kev's Avatar
Amen to that. A cooler is cheap insurance...well, as much as you can expect, when you run a loose(er) converter. A decent one runs around $50.00-$75.00 and can be put in in about 30 minutes in the driveway. Run decent trans fluid or even some of the special Royal Purple or B&M trick shift stuff. I ran the hell out of my car up and down the Interstate everyday. The temps here are in the 100's in the summer and the car was still on the original (67K) trans. before I replaced it with the 4L65 from Finish Line Transmissions.
Old Jul 9, 2005 | 05:57 AM
menlatin's Avatar
^^ Hey, not to steal the thread, but is that your car in the pic???? I see that car alot as i go between grapevine and denton.
Old Jul 9, 2005 | 07:14 AM
dsz28's Avatar
With a high stall your car will sould like wot around town. Thats too much attention for me.
Old Jul 9, 2005 | 07:17 AM
93LS1RX7's Avatar
I think he is the popo in the pic.
Bad boys badboys whatcha gonna do
Old Jul 9, 2005 | 09:55 AM
jxaxsxoxn's Avatar
The first high stall converter I used was great.
Until I was just cruising down a wet highway at 65-70 mph, right around the stall speed it was starting to spin the tires and get loose. If I wasn't paying attention I could have lost it.
After reading your post about the stock converter in a 4L80E you might also want to think about the downsides of a stock stall speed.
Like stalling (engine shutting off) at idle with a bigger than stock cam, sluggish performance up to the power peak, etc.
Old Jul 9, 2005 | 10:28 AM
4mula's Avatar
its gonna be loose and a bitch on gas
Old Jul 9, 2005 | 10:41 AM
blkZ28spt's Avatar
Downsides are far outweighed by the benefits, IMO. I daily drive a TCI SSF4000. Only things that ever bother me are how it often sounds like I'm giving it more gas than I am and increased gas conumption around town. The first one isn't a big deal at all, and I can live with decreased city mileage. One of the things you must deal with when buliding a high powered, go fast car is gas consumption.
Old Jul 9, 2005 | 01:13 PM
jlrz28's Avatar
10 Second Fun Car
I had a higher stall converter and of course it spun up alot more and had a hard time keeping alternators on the car, and my AC compressor started to make some funny noises too.
Old Jul 11, 2005 | 05:16 PM
FACE's Avatar
I have a hard time believing these problems were related to a high stall. Unless you have a 4000+ stall and 2.73 rear, it doesn't spin up much higher before taking off.
Old Jul 11, 2005 | 05:26 PM
blkZ28spt's Avatar
I also HIGHLY doubt that was the converter.
Old Jul 12, 2005 | 10:35 AM
SteveC's Avatar
From: Poway, Ca. where GOD and the sun always shines
My understanding is once lockup (1:1) is achieved, the converts work is done until it unlocks.
SteveC
Old Jul 12, 2005 | 02:57 PM
FastKat's Avatar
True, but I think it only locks up after the two pieces of the converter (pump and turbine?) are moving at close to a 1:1 ratio. That's frequently on the highway or when you are at a cruise speed. It's everything that happens before that.... getting close to the 1:1 ratio.... that's the tricky part.
SteveC
Old Jul 12, 2005 | 04:04 PM
12secSS's Avatar
Actually, the TCC locks up at a predetermined MPH ... which can be altered by HPTuners or the like. Pump and Turbine speed have nothing to do with lock up.
