Help with this mod!
Old Jul 10, 2005 | 03:29 PM
nate99 TA's Avatar
Default Help with this mod!
In an attempt to increase shift firmness i am going to increase the line pressure by following the link below.I cannot figure out how the connector comes off the solenoid.I have the car jacked up so space is limited and i am not very familiar with an A4 anyway.Thanks for any help!
http://www.ls1camaro.net/sections.ph...ticle&artid=27
Old Jul 10, 2005 | 09:29 PM
Pewterpower's Avatar
Its held on by a clip (I think its called an E clip???) If you're under the car, on your back, looking up at the solenoids...then you will be staring directly at the back side of the clip. Use the flat blade of a screwdriver, or needlenose pliers, to pry and pull it out.
Old Jul 10, 2005 | 09:44 PM
here ya go:
Look at figure 1
http://www.teckpak-fitzall.com/teckf...ds/k84825u.pdf
Old Jul 11, 2005 | 08:56 AM
nate99 TA's Avatar
Thanks,I finally got it.Didn't see much of a improvement though.
