Cracked Flywheel
Happens because GM changed the flexplate design
and took some "meat" out of it. If you have the
trans off, switch to an earlier year flexplate like
I did. Or a fancier one, but the early stocker seems
to be adequate. Look up "crack flexplate", more than
a few instances reported here.
Mine completly broke and bent into three pieces. It is a 2001-2002 problem. I got a TCI flexplate, which is a flywheel, for $190.00 it is suppose to take alot more punishment than the stocker. Check out Speed INC. Look for transmission parts.
From: Poway, Ca. where GOD and the sun always shines
The TCI SF29 flexplate is the way to go, both Jeg's and Summit sells them for $199. I replaced mine in my 01 Z28 when I did the TC change, you will need longer bolts though.
It is the 01 & 02's that have the thinner plates.
SteveC
SteveC
What about 6.0L plates or other truck plates? Are they different than the 5.7L plates? I would imagine they'd be a little thicker.
SteveC
SteveC
