How Much Can The Rear REALLY Take (A4)
Tony
I dont think i've ever experienced that in my A4. Wheelhop is whats gonna really put the strain back and forth on the rear end. Keep it from doing this (which you shoudnt even have to worry bou cuz you have an A4) and you'll be fine.
also:
go ahead and spend 100$ and get a TA cover. they certainly don't hurt the rear and they ONLY could help it.
<strong>(which you shoudnt even have to worry bou cuz you have an A4) </strong><hr></blockquote>
Many A4s have gotten wheel hop. I had it. LCAs cleared it up though. Don’t go thinking that A4s can’t get wheel hop...
If you can swing it, get a 12 bolt (or equivalent)
If not... ride that horse till it dies on you.
Avoid wheel hop and you "should" be fine.
Folks that want to cure wheel hop need to look no further than STICKY tires. Over the years i have had cases of wheel hop (ALWAYS ON RADIALS) Once I would put the "money" tires on. Zero wheel hop.
I ran mid 11's with the rear suspesion completely stock. I only upgraded to the Lakewoods, because, "they were there".
Go for it dude, just avoid the "Dreaded HOP" <img src="graemlins/fluffy.gif" border="0" alt="[Fluffy]" />
Back to thread -> like everyone said, there are plenty of people running 10's with an a4 with stock rear end. The tranny is usually what will go first. There are a LOT of people out there(not online or reading about mods) who just bolt on blowers to their stock car and beat the **** out of it and it lasts fine. Of course they probably arent as hardcore racers as the majority of us are, but none the less theirs are lasting fine. Get rid of the wheel hop and you should be pretty good until you get into HIGH hp and run some serious tire. I cant wait for my vortech 9lb in the next few months...we'll see how the rear end hangs. Hope this helps
-dan
I on the other hand am the complete opposite of the spectrum. I went into this with the confidence that - no way can it go. Boy was I wrong, and it went when I was at the track 150 miles away instead of the one that is 8 miles away.
Instead of spending the money to rebuild the crappy 10 bolt I invested in a 12 bolt. I didn't have any horrendous wheel hop before. A little here and there, but it wasn't bad enough to where it should have caused the rear to go.
Just saying, always make sure you have the option available to you in case something happens. I was running 3.73's, ST3500 and BFG Drag Radials and it happened on a mid 12 second pass... go figure.
It shouldn't happen to an A4, but every now and again it does, just saying, us A4 guys gotta stick together, don't get too overly confident!!! <img src="gr_sad.gif" border="0">
It is a VERY good philosophy to never beat on any parts that you can’t afford to replace at any time. Problem is, not too many of us can afford that philosophy... <img src="gr_sad.gif" border="0">
I am referring to E.T. Streets or Drags. Not any kind of radial. DR or not DR.
I have not run my car on radials at the track since I bolted in my first 2800 converter.
Good luck.
Campbellini'
