lost 3rd after trans-go fuddle install.
ive put 10k on this setup, and changed the trans fluid today and it looked brand new still!
but ur right, listen to the pros, just dont get frustrated with that trans go!
i also just recently had tq managment removed since i got hte cam and hte mail order tune, and im pretty sure my well known dyno tuner messed with the trans adjustments some cuz its really shifting its *** off now!
I'm sure some will dissagree but I personally know a few guys that are doing this and I also know a guy that builds transmissions for living and is damn good with the 4L60E's and he has done this many times himself.
My overflow vent tube is clipped to my torque arm, came that way from the factory.
Rob (Bad30th)
kevin
BTW does any body have Rock-On's telephone # just in case.
A bad 1st-2nd shift command in the program will make your tranny feel its toasted when infact its not.
I would also recommend getting someone to log your transmission while driving, and check your tranny temps. Too small hoses and even new coolers can obstruct flow causing heta buildup and slipping.
So I'd say yes, it can happen. To me it sounds like you might have some toasted internals in that tranny.
Glad to hear it's okay. Hit me up on AIM sometime, I'd love to talk to you about it.
