How to fix a leaky trans cooler?
Old Aug 14, 2005 | 03:45 AM
Jimmy P's Avatar
Default How to fix a leaky trans cooler?
I got a Permacool 30,000 trans cooler, and when I put it on, I noticed it was leaking from the backside of were the barb hose fittings go on. At first I thought I didn't put the fitting on tight enough, but then I realized it wasn't leaking from there, but instead is leaking for the actual trans cooler. Its a small leak, nothing drastic. When the car is parked, it may leak 1 or 2 drops of trans oil every minute, but I am thinking it leak more when im driving and going WOT. Any thing I can put around it that might help? I know I should of just sent the cooler back, but I had just installed it and wanted to see how it compared to the B&M unit I had. Any advice? thanks
Old Aug 14, 2005 | 12:04 PM
gwj's Avatar
gwj
From: Live Oak, FL - in the woods where the creatures lurk.
I'm not familiar with that brand. Are the fittings threaded in? If so, unthread them and use some teflon pipe thread tape. If not, I would trash it, unless it's in an easy place to weld.
Old Aug 14, 2005 | 07:51 PM
CrawlinWS6's Avatar
Import Patrol
When you are at wot your pressure in your trans will be higher causing a bigger leak. I don't think it is worth a $2,000 screw up, i would just take it out and get another one, if you are hard up to drive the car, get some brass fittings and reconnect the lines, and drive with out a cooler for now
