Huge problem after SS4000 and 3.73 install
Old Aug 20, 2005 | 05:22 PM
TA4U2NV's Avatar
Default Huge problem after SS4000 and 3.73 install
Alright, the local performance shop installed my Yank SS4000 and 3.73's, and I was supposed to get the car back today. Well the guy called me and said that we was making some test runs in the car, and he had driven it for about 10 miles, and when he went to park the car, he said that it all of a sudden quit pulling in drive, reverse, first, second, and third. he said it just acts like it's in neutral when he gives it gas, nothing is turning. He said no fluid is leaking and the fluid levels are just fine. Does anyone have any idea what the problem could be, becuase he's not even sure what the problem is. Help?
Old Aug 20, 2005 | 05:59 PM
Yank's Avatar
Have him pull off a cooler line and see if there is fliud flow, if not he broke the pump gear when installing the converter or the input shaft spun in the input housing, if fluid is flowing when running and also check that they put in the correct amount of fluid
Old Aug 20, 2005 | 06:06 PM
TA4U2NV's Avatar
He said he called you guys but no one was there and he left a message. I'll get this info to him asap. thanks.
Old Aug 20, 2005 | 07:23 PM
Blacker's Avatar
Ah, damn. That is not good.
Old Aug 20, 2005 | 11:22 PM
Kounsy's Avatar
It could have busted the planitary shell. the 4l60e's are bad for that.
Old Aug 20, 2005 | 11:33 PM
RamAir02TA77's Avatar
I had a similar problem except right after I installed the converter the car didnt move. It turned out being the transmission pump. Im pretty sure my transmission pump got messed up by not seating the converter right. Also my transmission fluid wasnt getting hot.
Old Aug 21, 2005 | 04:49 PM
TA4U2NV's Avatar
TTT. All info thus far is appreicated. Anything else it could be?
Old Aug 21, 2005 | 11:36 PM
1QuickT-A's Avatar
Sounds like a case of "installation error"...
Old Aug 22, 2005 | 03:06 AM
strokedls1's Avatar
I've had 2 pumps go out and that is exactly what the result was. Could be a case of not seating the converter all the way which will put pressure on the pump and break it. That would be my guess of what happened. Good news is a pump only costs about 65 dollars to replace.
Old Aug 22, 2005 | 11:13 AM
11SECSS's Avatar
If the front pump broke then theres no way he drove it for ten miles ....if the convertor was installed propely it broke when he first put it into gear..
Old Aug 22, 2005 | 04:44 PM
black02-z28's Avatar
I can second that. Sounds like bad timing to me, trans prob took a dump. If the TC was not installed on the pump it would not move at all, no line pressure...
Ed
