4l80e question experts inside
Old Aug 24, 2005 | 10:08 AM
69firebird's Avatar
Default 4l80e question experts inside
Hi,
Im wondering does the shifter linkage in the tranny have the traditional swing arm style, that a normal shifter linkage hooks up to?? Mine ust has a screw sticking out of it and that doent look right.
also how do I get a dipstick hooked up for it?
thanks again
ed
Old Aug 24, 2005 | 05:52 PM
69firebird's Avatar
hmm I guess I need a shifter I have a 6spd car, and didnt know all I had ever seen is the ones that have a toggle style manual shifter, where can I buy something like this
also any clue on dipstick?
thanks
ed
Old Aug 25, 2005 | 01:52 AM
strokedls1's Avatar
You can get a dipstick from summit racing. They are braided steel ones from lokar. My is 36" I believe, but it is a little shorter then I would like. I think you can order them longer then that, but just call and ask for a lokar 4l80e. I guess I am not quite sure about your shifting question. On mine there is a short rectangular arm with a bolt that screws into it. The shifter linkage will go on that and is held in place by the bolt.
Old Aug 25, 2005 | 10:07 AM
69firebird's Avatar
On mine all there is is a bolt sticking out, I dont see how a shifter linkage will hook on to that.
Usually there is a halfmoon shaped peice of metal with holes in it to connect the shifter to.
however does the tranny really need the manual shifter?
Old Aug 27, 2005 | 03:08 PM
FastKat's Avatar
Here's a pic from my 2003 4L80E
Originally Posted by 69firebird
Hi,
thanks again
ed
Old Aug 27, 2005 | 03:15 PM
69firebird's Avatar
fastkat,
that is the exact picture I was needing. thanks a ton
just e-mailed the guy I got it from
ed
Old Aug 28, 2005 | 03:44 PM
lisa33's Avatar
http://home.koping.net/u3243a/vinter...5/DSC02203.JPG its a 1994 modell, Ill toke the arm from my 4l60e and mounted it direct on the 4l80e just needed a little adjustment on the wire no problem at all
Old Aug 28, 2005 | 11:12 PM
DeltaT's Avatar
That shaft that your bolt is attached to has one or 2 flat spots on it to allow a plate to slip over it and lock when you add the bolt.
Lokar makes a cable shifter kit that works with the 4L80E and most floor shifters.
I also used the Lokar dipstick and it is good quality and does not leak.
Jim
Old Sep 13, 2005 | 09:16 PM
FastKat's Avatar
no prob man, any time.
fastkat,
ed
Old Sep 14, 2005 | 05:34 AM
smokinHawk's Avatar
hey man you got your manafolds upside down
