Cracked flywheel. Can I weld it?
Old Aug 27, 2005 | 12:55 PM
BigBlockChev572's Avatar
Default Cracked flywheel. Can I weld it?
OK guys. Some of you might be aware I have a cracked flywheel. This sounds silly but I haven't even had the time to look at it. But I do know it is cracked. If the cracks are hair line cracks, or even widespread cracks, can I weld it? I figured I could weld over the cracks (hardsurfacing even) and then get it balanced. I can't afford a TCI. Would this work? Or should I not deal with it and hope for the best with a new OEM?
Thanks,
Philip S.
Old Aug 27, 2005 | 01:36 PM
jxaxsxoxn's Avatar
You're going to weld it and have it rebalanced? And thats going to be cheaper than a new one? Open your eyes man.
In other words take the old one off and throw it away, buy a good new one when you can afford it.
Old Aug 27, 2005 | 02:18 PM
How much does balancing cost? I guess I'll just buy a new one then. I'd weld it myself.
Philip S.
Old Aug 27, 2005 | 04:15 PM
BubaGumpShrimp's Avatar
i forgot to tell you in the last post you made about the flywheel. The 2001-2002 flywheels are the junk thin ones(something i need to look out for also). Go to the junk yard and find yourself a 98-2000 wheel, thoes are the thicker ones which i never heard about anyone cracking...
Old Aug 27, 2005 | 06:27 PM
SWEET! Thanks for the info man! That probably saved me. So I'll go pick up one of those from the stealership soon then.
Thanks!
Philip S.
Old Aug 27, 2005 | 08:47 PM
yea i know, i had to look into it when i seen a few posts about it and found out the 01-02 years were the crap ones. Most upgrade to the tci one but if no one cracked the 98-2000 models than why not use one of thoes..
Old Sep 7, 2005 | 10:01 PM
vortec_7's Avatar
Thanks!
Philip S.
I have a 2000 flexplate for cheap, if you need it pm me. I switched to M6.
Old Sep 10, 2005 | 03:47 PM
MyCarIsSLow's Avatar
ive warped my 2000 flexplate..
Old Sep 13, 2005 | 02:49 AM
MasterMind's Avatar
I warped mine too, pretty bad with a crappy stall converter.
Old Sep 24, 2005 | 04:58 PM
mine was with a tci 3500
Old Jan 2, 2015 | 11:44 AM
wayneSS's Avatar
Good informative info!
Old Jan 2, 2015 | 11:57 AM
Circle-D_Brian's Avatar
A tip for you guys looking at stock flex plates, the new 6l80 transmission cars and trucks come equipped with a dished LS bolt pattern flex plate that interchanges with the f body. We have found the newer plates to be a higher quality than some of the old stuff.
-Brian
