4l60E Transgo
Old Aug 27, 2005 | 06:03 PM
desouth@adelphia.net's Avatar
Default 4l60E Transgo
1999 Camaro Z28 4l60E
Installed a transgo shift kit ,servo etc.After I installed the pan, and pulled the drain pan away I found a Pin in the drain pan. It's 1 3/4" long l about 5/6" diameter slight chamfer on each end looks like the pin the piston rides on in the accumulator but bigger diameter. Have no idea where it goes, must've fallen out. Any Ideas?
Old Aug 27, 2005 | 07:48 PM
jxaxsxoxn's Avatar
It sounds like the accumulator pin that goes in the case above the valve body.
1 3/4" x 5/16" right?
Old Aug 27, 2005 | 07:52 PM
1 3/4" Long x 5/16" Diameter
Where Exactly Does it Go? Your Help Much Appreciated!
Old Aug 28, 2005 | 11:27 AM
Wink
It was indeed the accumulator pin. I had installed it and the car sat for a week, Gravity! Thanks alot for the input!
