6l80e
Old Oct 30, 2005 | 01:36 AM
James B.'s Avatar
I would like to see how these hold up in the long term. I'm not a fan of 3-pinion planetaries or of multiple-event shifts, but the torque handling numbers and close gear ratios are enough to keep an open mind.
There are three different bellhousings that I know of.
1. Torque tube bell for Corvette
2. Small bell (flat on top) for Cadillac
3. Big bell with standard SBC/BBC bolt pattern.
I have heard the controller for these is onboard. I have no idea how they get electronics to live in AFT, but apparently that is exactly what's happening. The transmission will take external inputs from the PCM (TPS, Brake Switch, tach, possibly MAP) and it will provide current gear (PRNDM1) and VSS. The "M" mode of drive will be a manu-matic up/down mode selectable by steering wheel or shifter controls. I cannot confirm this controller information.
The interface with the PCM will be similar to the way the Allison works with the HD trucks. The trans controller is external from and linked to the PCM and capable of commanding the PCM to run the engine in limp mode.
Old Oct 30, 2005 | 11:32 AM
AronZ28's Avatar
I thought they were going to put this tranny in the base C6 with the LS2, the XLR, and all the new GMT-900 trucks and SUV's. They should make it standard across Cadillac's entire lineup too.
Old Oct 30, 2005 | 02:32 PM
Hennytime's Avatar
the 6l80 is going into the new tahoe, and in the 06 vette, there wont be a auto z06 as of right now
Old Nov 3, 2005 | 04:03 PM
blown2kss's Avatar
if you check out the forum on digitalcorvettes.com they have pics of this in a zo6 with paddle shifters.
Old Nov 3, 2005 | 04:06 PM
Darksol's Avatar
Originally Posted by snketr
You guys are missing the most important part. The C6 is a rear trans (forgot terminology) like the C5. It'd be incredible amounts of fab to get it to work.
Andy
transaxle?
Old Nov 3, 2005 | 04:22 PM
blown2kss's Avatar
I am just letting you know what I found on another web site that seems to get this info quicker than any of the other forums I've been to.
If GM is doing this obviously it was planned so the car would already be fabricated to handle this trans that apparently isn't much bigger than a what they are already using.
Old Nov 3, 2005 | 04:57 PM
Yank's Avatar
here is the specs and photo on it
http://media.gm.com/us/powertrain/en...80%20(MYC).pdf
http://media.gm.com/us/powertrain/en...0BFL%20LoR.jpg
Old Nov 5, 2005 | 12:15 PM
Yank's Avatar
Originally Posted by ws6gluemaker
transaxle?
I found my '99 Hugger Orange SS in back of the shop.
I guess this is what you are talking about.
Old Nov 5, 2005 | 12:52 PM
CAT3's Avatar
Restricted User
Now thats just plain syk! Way to go Mike..
Old Nov 7, 2005 | 03:07 PM
Yank's Avatar
The engine is going to be the best part!
Old Nov 7, 2005 | 03:10 PM
snketr's Avatar
Now, you need to put a bellhousing on it and an adapter so we can use it in our cars. Not just the Vette.
Old Nov 10, 2005 | 07:52 PM
  #32
Turbo V6 Camaro's Avatar
www.rosslertrans.com
^^ he has parts already in the makes for it
