Can you test flash stall in 2nd?
Dan
Stall speed is measured when the converter output shaft is at zero rpm at the instant that it will start to rotate. If you are doing 20 mph, the output shaft is rotating. Also it sounds like you were using part throttle and not WOT in order to prevent it from downshifting.
If you have second gear start, you could use it to get a better estimate of stall speed (compared to measuring it in first gear) when flashing it from a dead stop.
L8r
Will
<strong>Would it matter if the tires spun to get an accurate reading?
</strong><hr></blockquote>
Yes, because you can't fully load the converter.
