Trans not downshifting
well you should be thinking of an aftermarket converter espically with the cam you have.. Im upgrading my midwest converter to a fuddle and will be selling my midwest 3,000 stall so if your looking to change the converter i could sell you mine for 250 if your sure your converter is bad or if you just want to upgrade. Hell we might get a better deal on the install if we both go together.
im definitely gonna upgrade my converter. how exactly do you tell if its bad. i just pulled the pan again and drained the fluid. it was a dark color not bright red. however there were no shavings or chunks of anything. it looked like the fluid had silver sparkles in it. i put it all back together with new fluid and filter again. as soon as i pulled outta the drive way i punched it at about 25mph and it wouldn't kick down. it shot like a rocket three times from a dead stop. then on the fourth it seemed like it started in second and then jumped to fourth and felt like the converter locked up all one after the other. then as soon as it finally made it to about 50mph i left off and punched it. it kicked down and took off fine. is there a possibility of a valve sticking or is the converter bad. im about to say screw it and switch to a 6 speed.
well i just took it to a tranny shop. they said its definitely electrical. there is nothing wrong with the trans itself. he seems to think its the pressure control solenoid. its not getting the right volts, but its still operational. therefore the computer wouldn't pop a code for it. hell if i know im just gonna drop it off there and let him figure it out.
well after some more reviewing i believe i have found the problem. when i had the cam installed i didn't change the min/max for the MAP. there is a thread on here that talks about that. it will make your car start off in second gear if its not changed.
