A4 kicks out of gear?
Old Oct 1, 2005 | 04:36 PM
One Bad Z's Avatar
Default A4 kicks out of gear?
built 4l60e w/3500 stall
A few weeks ago i made a 5mph or less turn and it banged loud and kicked out of gear. Two minutes later at 50% throttle it kicked out again. It did it again last night. What could be causing this?
Old Oct 1, 2005 | 06:10 PM
BubaGumpShrimp's Avatar
my guess is the fluid level is low and taking a turn will push the fluid away from the pick-up tube and it will suck air thus kicking the trans out of gear.. Check the fluid level with the car running. Then get in the car and move the selector in reverse for 5-10 sec, than move it to 1st for 5-10sec,2nd,3rd and od for 5-10 sec than back to park. Re-check the fluid level.
thats my best guess so far..
