convertor question
Old Oct 4, 2005 | 08:05 AM
NC98Z's Avatar
Default convertor question
What determines when an aftermarket cam requires a higher stall. They say a 224/114 is pushing the limits of a stock converter. What limits? Can a stock converter cause idle problems with an aftermarket cam?
Old Oct 4, 2005 | 02:28 PM
Ragtop 99's Avatar
The stock cam is too big for a stock stall. Peak TQ is over 4000 rpm and a stock stall is about 1800 rpm. That's way too low. Running a stock stall just kills you off the line and on the upshifts.
Most people use an 800 - 850 idle with a 224 cam. An idle speed of 750+ on a stock converter is about when you will start feeling it fight the brakes coming to a stop.
Old Oct 4, 2005 | 03:15 PM
Joel_SS's Avatar
I drove around on a stock stall with a 226/234 cam and an 900 RPM idle and I was fighting to stop the car. I had to have the brake pedal practically mashed to the floor to keep the car stoped, and it would slam into gear when shifting into D from R or P
