AN fittings on a trans cooler overkill?
Are AN fittings and braided lines overkill? Will I be ok with the rubber hoses and some clamps?
FWIW, I stayed with the barbed ends and hose clamp on the SS and am using them on the 'Vette and have never had a problem again, but I do hear of them coming loose on other cars now and again. I'd feel better with ANSI fittings, so if you can do it easily, it sure wouldn't hurt anything.
98A4LS1 my cooler came with 4 ft. of rubber hose and I had some left over, so if you get 4 ft of line you should be good, not sure about the fittings though.
