What tranny cooler do y'all use?
<strong>Girlie men!!! With Hayden installed near bottom and centered on the condenser
</strong><hr></blockquote>
This bitch runs a FTRA so center mount is out.
<img src="graemlins/gr_judge.gif" border="0" alt="[judgement]" />
<strong>
<img src="graemlins/gr_judge.gif" border="0" alt="[judgement]" /> </strong><hr></blockquote>Hmmm!! I guess there's not too much you can do to go around that with the set up you have. I have seen this and opted to not use it for just this type of situation. Good luck. You fast guys need all the help you can get with your high stalls and high torque/hp just = major heat!!!!
<img src="gr_images/icons/mad.gif" border="0"> <img src="gr_images/icons/mad.gif" border="0"> <img src="gr_images/icons/mad.gif" border="0"> <img src="graemlins/gr_devil.gif" border="0" alt="[devil]" />
[ February 12, 2002: Message edited by: FaSS Blac ]</p>
<strong>
With it sitting off the airdam like that, it gets looooots of flow.
Dope</strong><hr></blockquote>
I'm thinking of switching to your mounting style but I have a question:
Does it work well in slow stop & go traffic too?
With it currently on the condensor, when my fans kick on sitting at a stoplight, I can see the tranny temp drop. That helps in heavy traffic as the converter is being worked hard, but the car's speed is below 30 mph.
With the stock converter, I was seeing tranny temps of around 210 with extended idling at a drive-through in the summer/before cooler. After cooler install/stock converter/summer never saw extended hot idle temps above mid 180s. No hot weather ATAP yet with the ST3500.
Looking at it.... how would it get any air flow in stop and go traffic? Especially free way stop and go traffic that might last for over an hour.
If you live in Houston or another HOT climate city... i would definatley NOT recommend this spot for a tranny cooler.
Mount it where the radiator fans will pull air over it. So it will get air no matter if the car is moving or not.
Just my thoughts...
(every body has their own ideas.... do what makes you happy)
http://www.johnbrown.net/wilwaxu/transcooler.html
