What tranny cooler do y'all use?
Old Feb 12, 2002 | 12:05 AM
Raughammer's Avatar
D(irecto)r Pepper
Default What tranny cooler do y'all use?
I use a B and M 16000GVW cooler mounted on the passenger side of the A/C condenser.
Anybody else?
Old Feb 12, 2002 | 12:20 AM
SSBoy's Avatar
Default Re: What tranny cooler do y'all use?
B&M 19000 i think, maybe its 16000. Got it mounted inside the Fans.
Old Feb 12, 2002 | 02:21 AM
RyanJ's Avatar
SSU Moderator
cheap assssssss Hayden unit (16k GVWR i think). mounted real high in the center of the condensor. couldnt reach the tabs to mount it low...ill be re-doing it at some point.
Old Feb 12, 2002 | 02:33 AM
TransAm2002's Avatar
I have a B&M 19,000!!!
Old Feb 12, 2002 | 02:34 AM
Dope's Avatar
B&M 24k mounted Dope style.
Dope
Old Feb 12, 2002 | 02:46 AM
RyanJ's Avatar
SSU Moderator
Dope, i have the pics of yours you posted long ago. i know its hard to tell, but do you get ample flow through the cooler with it mounted like that?
Old Feb 12, 2002 | 03:07 AM
Dope's Avatar
As far as I can tell. I have not seen above 180 degrees on the fluid temp, in the middle of the summer.
With it sitting off the airdam like that, it gets looooots of flow.
Dope
Old Feb 12, 2002 | 07:53 AM
Ragtop 99's Avatar
16,000 GVW plate type cooler (forgot brand) mounted on bottom passenger side of condensor.
Old Feb 12, 2002 | 08:46 AM
5litereater's Avatar
I have the B&M 16000GVW also. How is everyone mounting theirs to the bottom of the condesor, and is it keeping tranny temps low enough in the summer? I have mine mounted to the bumber and air dam in the front of the car, but I want to move it. It blocks off too much air flow to my FTRA right now.
Old Feb 12, 2002 | 09:22 AM
Top Fuel's Avatar
B&M 19,000 here. Its mounted on the passenger side of the air dam.
later,
Steve
Old Feb 12, 2002 | 10:02 AM
Skelton's Avatar
B & M 24k. No condensor so its mounted low on the radiator
Old Feb 12, 2002 | 10:17 AM
Matt98SS's Avatar
I have the 24,000, like Y2K i don't have a condensor so its mounted in front of the radiator low
Old Feb 12, 2002 | 10:23 AM
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
B&M 16,000GVW. It’s mounted to the bottom passenger side of the radiator/condenser support frame. Keeps the temps below 200 until I really start to beat on it...
Old Feb 12, 2002 | 11:59 AM
WILWAXU's Avatar
24,000 B&M mounted to the Ram Air scoop <img src="gr_images/icons/wink.gif" border="0">
Old Feb 12, 2002 | 01:59 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
B&M 19,000 GVW mounted on the radiator where the AC condensor used to be.
178-185F on the highway.
Old Feb 12, 2002 | 03:07 PM
mmiller's Avatar
Texas Director
B&M 19,000 GVW mounted on drivers side condensor.
Old Feb 12, 2002 | 04:21 PM
Loco's Avatar
B&M 19k on the passenger side of the condenser.
Old Feb 12, 2002 | 05:19 PM
gwj's Avatar
gwj
From: Live Oak, FL - in the woods where the creatures lurk.
B&M 24K mounted low on pass side of condensor.
136 degrees tranny temp at 70 ambient cruising @ 80 mph/1900 rpm.
Old Feb 12, 2002 | 05:56 PM
Dope's Avatar
[quote]Originally posted by Ragtop 99:
<strong>
I'm thinking of switching to your mounting style but I have a question:
Does it work well in slow stop & go traffic too?
With it currently on the condensor, when my fans kick on sitting at a stoplight, I can see the tranny temp drop. That helps in heavy traffic as the converter is being worked hard, but the car's speed is below 30 mph.</strong><hr></blockquote>
Like I said, highest I've seen was ~180 in the summer (stop + go on a 4 lane highway for 20 mins, 70-80 degree ambient temps).
I 'only' have a 3000 stall though. For reference, however, with the STOCK converter and NO cooler, I saw more than 240 degrees several times in the summer (more like 90 degrees though).
Dope
Old Feb 12, 2002 | 05:57 PM
Bob2of3's Avatar
Wheels up Director
I got the Smallest Supercooler mounted right were the front bumper support used to go <img src="gr_stretch.gif" border="0">
Here's the front shot
And the 2 upper mounting points
LAter <img src="gr_grin.gif" border="0">
