2-3 shift
Old Oct 8, 2005 | 02:43 AM
GDM Z28's Avatar
Default 2-3 shift
well the car has a rebuilt tranny and a 3200 stall as of 2-3 months ago.....no shift kit....tonight i was having fun with a buddys c6 and at the end of 2nd it would bounce of the rev limiter at 6500 and wouldnt shift.....since the tranny was just redone im thinking its because i dont have a shift kit but i am looking for other inputs...TIA
Old Oct 8, 2005 | 06:54 AM
Hooper's Avatar
Did you have your shiftpoints adjusted?
Old Oct 8, 2005 | 01:02 PM
GDM Z28's Avatar
no i didnt and someone else was telling me this is probally the cause.
Old Oct 8, 2005 | 05:12 PM
spy2520's Avatar
mine does the same thing, but i'm pretty much all stock on the drivetrain. kinda pisses me off. i still dont know what to do.
Old Oct 8, 2005 | 10:22 PM
andy1h2004's Avatar
mines is doing that right now and I was told my neutral safety switch is out, 1 to 2 then rev.'s. . Put a scanner on it and see if the computer has any trans. codes and see what gear the comp. says the car is in while it's in gear if they do not correspond then its that. mine will be in park and the car was reading reverse, while the comp. said 3rd ( I know sounds bad) so get it checked, good luck!
Old Oct 9, 2005 | 01:09 AM
spy2520's Avatar
i had HumpinSS (larry) check mine and just sitting there it would not read the correct gear, but we drove around a bit and while driving it read right. anymore info on this because if this is the fix i'm celebrating....
