Is A4 strong enough?
I autocross raced my car(engine braking and all),manually shifting back and forth from 1st to 2nd for over 2 years. Before getting away from that sport and put in a higher stall speed convertor(Vig3600) ,i did not put in a shift kit.Only added a Predator programmer,i did not get around to adding a cooler.
Raced my car for over 2 years around town and at the track that way with the Nitrous kit set at 150 rwhp the whole time.
Then changed convertors (1 better for the bottle) at 85,000 miles and my trans tech friend that swapped them for me did a trans (build) at the same time because i thought it should be really close to letting go.
He went all through the trans and told me,and showed me,that all the internals looked so good that . If he did not know i drove hard and raced my car like i do,he would guessed that these parts came out of a stock car driven only as transportation and not like a toy.
Now i know that is only 1 persons car and only 1 tranny out of how many out there.
But if mine did so very well, and i know how i drove/drive it....
I say very impressive job down by GM on this 1! Just my .02 worth.
P.S. My stock rear-end lasted until about 4 weeks ago,before it let go a few bearings and got really loud.
So i swapped it out for a low mileage M6 unit for the 3:42 gear advantage.
So i really don't think the A4 set up is as weak as it has a rep for.
I pull 1.54 60fts on spray with E/T streets regularly too... 1.61 all motor on DRL's
Dave
not a fan of the fricking auto tranny wish i had m6.. but then id probablly kill my rearend. maybe its my driving habbits.? My point is, there should be better quality control so that guys like myself barely making 400 hp shouldn't have to deal with a blown trans when there are plenty of people out there making much more power with the same trans.
I guess a good example would be the '03 Cobra. There are guys all over Detroit running 500-600 rwhp Cobra's out here with simple pulley swaps and tuning that don't have to worry about their bottom ends or stock T56s.
These cars were meant to be modded and meant to be ragged on. Isn't that what makes a muscle car great? Before the electronically controlled, cost cutting era, real muscle cars ran around with drivetrain components that belonged on full size pickup trucks, why can't ours?
But I do agree that the 6-speed guys have it rough with that rear. Their trans is much more violent on the axle and they seem to pop often enough that a better stock rear would be a reasonable request.
And I agree 100% that these cars are meant to be driven hard, and modded. And I think the 4L60E can hold up just fine if modded properly to keep up with major power additions under the hood. For stock or mild bolt-on cars, in most cases the 4L60E seems to last quite a long time. Granted, QC issues could account for some of the early failures (like yours), and for others there is still the issue of excessive abuse and/or poor maintainence.
I guess I'm one of the unlucky ones
Can't wait to get that trans in
