A4 to M6 conversion question
Old Feb 19, 2002 | 02:36 PM
nbm99ta's Avatar
Default A4 to M6 conversion question
I know how to install everything. I just want to know what to do about the computer and wiring? What all needs to change? Can I just get a custom program for my car? Are there any write-ups on this?
BTW - it's going in a 99' TA.
Old Feb 19, 2002 | 05:00 PM
The Guy in MY 99TA's Avatar
Default Re: A4 to M6 conversion question
I discussed this with Jsears and Justin99t/a at the race track a few weeks ago and they mentioned to me that a guy at Thunder Racing could program my computer to work with the conversion. I would like to know more about this myself, because I might do an A4 to M6 converion if I have any more problems with my A4.
I also have a few questions about the swap...... was it hard to install the clutch pedal? did you have trouble mounting the clutch master-cylnder? were you able to use the same tranny mount? the same driveshaft? did you have to modify the torque arm to work? and last but not least...... how much cutting was required for the shifter to fit through the floor???
I think that should cover my questions if anyone has made it this far with a swap yet
Josh S.
Old Feb 19, 2002 | 05:30 PM
Hp Joe's Avatar
keep the a4 you are going to regret getting rid of it. Why are you converting.
Old Feb 20, 2002 | 11:44 AM
nbm99ta's Avatar
[quote]Originally posted by The Guy in MY 99TA:
<strong>I also have a few questions about the swap...... was it hard to install the clutch pedal? did you have trouble mounting the clutch master-cylnder? were you able to use the same tranny mount? the same driveshaft? did you have to modify the torque arm to work? and last but not least...... how much cutting was required for the shifter to fit through the floor??? </strong><hr></blockquote>
Since I've done the swap before (just not in an LS1 car), I can answer these questions. The clutch pedal is part of an assembly which includes the clutch, brake, and gas pedals - all mounted on one bracket. It bolts right in place of the original.
Clutch master cylinder can be a pain. Just make sure you drill the holes in the firewall exactly like they are in an M6 car. It helps to have an M6 car you can you for a reference. If the U-bolt holes are off, the master cylinder will be crooked, and that can cause the pushrod to come off the clutch pedal when you press it. If this happens, you can shim the master cylinder on the U-bolt to compensate.
The original tranny mount, driveshaft, and torque arm will work.
I used an air hammer with a cutting bit, and an air die grinder with a cut-off wheel to make the hole. I bolted the tranny up & put the crossmember on, so then I could trace an outline on the floor board of where the shifter hole should be.
Hope this helps!
Now, does anyone know if LS1 Edit will be capable of re-programming an A4 car to think it's an M6?
Old Feb 20, 2002 | 04:23 PM
BIGBOS's Avatar
I am in the process of doing the opposite....m6 to a3...but there is not that much CPU work involved
Old Feb 20, 2002 | 08:25 PM
Thanks NBM! The biggest thing I was worried aboutw was the master cylinder and getting under the dash to work with the pedals...... I worked on a Ford Truck not too long ago(in school so I didnt have much of a choice) and had to replace the pedal assembly so I dread doing that and that for me will probably be the worst part since I'm about 6'5" and about 280 lbs and there isnt much room to work... I PRAY my tranny will last me till I can get out of school and get a steady job!!! Pray with me guys!! LOL Thanks for the info!
Josh S.
Old Feb 21, 2002 | 11:27 AM
nbm99ta's Avatar
[quote]Originally posted by BIGBOS:
<strong>I am in the process of doing the opposite....m6 to a3...but there is not that much CPU work involved</strong><hr></blockquote>
What are you doing with your old 6-speed setup? I may buy it from you. Where is Elk Grove? I'm originally from Southern Illinois, and have family there.
Old Feb 21, 2002 | 11:29 AM
nbm99ta's Avatar
<strong>Thanks NBM! The biggest thing I was worried aboutw was the master cylinder and getting under the dash to work with the pedals.</strong><hr></blockquote>
No problem! your welcome! I was dreading the pedals too. It's really not that hard, it's a direct bolt-in replacement.
Old Feb 21, 2002 | 01:04 PM
RacerX's Avatar
If LS1 Edit would do such a thing as re-program he car to think it was an M6 instead of an A4 then I wouldn't mind setting it up with all the hardware to support a quick swap out. I like driving both M6 and A4's
Old Feb 21, 2002 | 07:44 PM
I SAY <img src="graemlins/gr_guns.gif" border="0" alt="[guns]" /> A4 ......... I hate mine and wish I did have a 6speed b/c my freind and his dad have a 95 z28(son) and a 99 SS(dad) and they are both 6-speeds and the SS has the Pro 5.0 and it is a nice shifter and they are BOTH A BALL TO DRIVE!!!!!!!
Josh S.
