Brake line install help.
Old Feb 20, 2002 | 11:17 PM
qwik3r's Avatar
Default Brake line install help.
Wondering if there is any online resource with installation instructions for the earl brake lines (with pictures etc). Thanks.
Old Feb 21, 2002 | 12:05 AM
Nine Ball's Avatar
LS1Tech Co-Founder
Default Re: Brake line install help.
moving to brakes section of site
Old Feb 21, 2002 | 08:58 AM
mitchntx's Avatar
Haven't seen any How to articles about it.
But, it's really quite simple and self evident.
Line wrenches are a MUST!
Make sure you use new crush seals on the banjo fittings when fitting up to the calipers.
Also, hose everything down really well with brake cleaner before you begin bleeding the air out. Makes it easier to see any fluid leaks.
The only head ache is installing the 5th line, where it connects the hardlines between the body and axle. The angle and access is kind of a bitch.
HTH
