Wiring N/R on Pro Ratchet, need help.
Restricted User
I will have the TH350 conversion finished (for the most part) tomorrow. I know I need to splice into the factory black N/R safety switch box, but not sure which colors for what. I have both WOT switches mounted to the Pro Ratchet, for the Nuetral and Reverse switches. Thanks.
If you use the OEM park/neutral safety wires (connect together purple and dark green) and the reverse wires (connect together brown and light green), the computer will know the trans is in a drive gear.
Make sure that the switches are adjusted right or the car will start in gear.
After you connect the wires to the p/n switch put it in gear and make sure that it will only start in p/n.
Alan
Alan
Restricted User
Alan, thanks.... I forgot to post the reply I copied from kp over here when I hit someone else asking the same thing. Damn it. I have two switches, so I was thinking I only have to splice together the Rev Lights and Reverse Gear together and then run the other side out of the switch & same for hatch and P/N. Anyway, thanks.
