Wiring for th400, reverse lights and trunk dont work.
Thanks
Jimmy
Does your power trunk work?
Let me ask you. How did you attach your shifter to the car? The guy that did the work on my car put a 2x4 piece of wood, attached it with 2 long bolts onto the car, then drilled a couple of screws from the shifter onto the wood. I got carried away when I was shifting and pulled to hard, and pulled one of the screws out of the wood, so I will have to get a drill and drill more screws in, or im thinking of getting a piece of metal and drilling it for bolt holes.
I have heard of some ppl using bolts with a tubular spacer, Lowes/Home Dept, but will find out in a bit when I go to finish the mounting.
on th stock NSS connector:
orange/black and Black/white are for the hatch release and letting the PCM know the car is in drive/reverse. No place to hook this up on an aftermarket shifter.
purple/white and DARK green are for the neutral safety switch.
brown and LIGHT green are for the reverse lights.
Thats what kp posted a few months ago, just found it on a search, assidently skipped this one the first few times.
Mike
What is the stock switch going to look like? Basically when I removed the Hurst shifter to tighten down the bolts, I saw a bunch of wires that are taped together. I didn't see a switch.
