TC installed=results
I have the same converter and I know it seems like your slower but in reality your alot faster (or at least you should be). It takes alot of gas for me to get going in reverse and moderate acceleration around town definately feels "sluggish". That's the nature of the beast. However, the tradeoff should be that when you go WoT from a dig it should light up the tires in smoke. When you go WoT from 40 mph it should feel alot stronger then it did before because the rpm's will flash to 3500. Shift extension should be around 4800 rpm's which should also help to decrease ET at the track as well as add 1 mph to your trap speed.
Your supposed to feel slower under part throttle but you should feel stronger on aggressive throttle and it should be insane under full throttle from a dig. It took me a week to get used to the converter but now it feels stock to me except when I get on the gas hard
You might want to get a dyno-tune to make sure your running ok (I was running wicked lean) and a shift kit is a great idea to help firm up the shifts if you feel it needs it.
