switching from m6 to auto. th350 or th400?
Old Nov 8, 2005 | 02:08 PM
silverbeast's Avatar
Default switching from m6 to auto. th350 or th400?
Hey guys, well im tired of the crappy clutches in our cars so im going auto. I will be adding a 150 shot of giggle juice on top of what ive got now so i need one that will hold up. should i go with the 350 or the 400 and why? I have 4.11's in my car now so what will be the best stall for that combo? I will switch back to 3.73's if i have to. If anyone has the upper part of the a4 console i will be needing one,thanks. Charles
Old Nov 8, 2005 | 02:18 PM
mike c.'s Avatar
bro.....i may join you in the m6 to a4 swap. i'm also tired of all this damn shi* with the ls1 clutch.
Old Nov 8, 2005 | 02:32 PM
Hambone 7's Avatar
you will most likely run out of rpm's in the 1/4 if you run a 3 speed with a 4.11 gear. I have a th350 and i get close to 5000 in 3rd in the 1/8 with a 3.73 rear.
Old Nov 8, 2005 | 03:53 PM
Steve Burger's Avatar
LS1TECH Sponsor
I just did this swap. Gotta tell you I love it. I used the M5 console and put a Cheetah shifter in there. It fits well. I have a built TH350 RMVB with T Brake and a 4600 stall converter. I also have a 4.10 gear. Last time out I was crossint the traps over 1200 at 6100 rpm. I am shifting at 6800.
Search in this forum and there are pictures of the shifter and info on the guy who did my trans. Jay Billingsly sent me to him.
Old Nov 8, 2005 | 08:32 PM
SUX2BU's Avatar
since your car is so heavy and you will be sprayin it i would go TH400. and as for a stall i would get a 4000 8" nitrous stall.
Old Nov 9, 2005 | 03:49 AM
thanks guys, i will be looking into this for awhile. this will be my winter project. i wish the 4l60e would hold up to that much power but i doubt it will.
Old Nov 9, 2005 | 06:25 AM
darrensls1's Avatar
4L60e definately wouldn't last
I also vote TH400 with 4000 Nitrous stall. And if you have the extra cash, the TH400 has a GV overdrive unit you can buy for $2500 if you absolutely have to have OD.
Good luck with the new project and welcome to the dark side of the force
Old Nov 9, 2005 | 09:58 AM
bandit383's Avatar
maddog 4l60e transmission rated at 700hp
Old Nov 9, 2005 | 12:30 PM
Schitzo's Avatar
I would go with TH400 with the kind of gears you are running out back and the fact that you can get OD later on.
Anyone getting rid of their T56 should hit me up coz I am looking for one.
Old Nov 9, 2005 | 03:01 PM
LS1TECH Sponsor
Build a 350 right and it wall handle that HP no problems. It will also be more efficient.
Old Nov 9, 2005 | 03:43 PM
MountainMotor's Avatar
I'm voting on the 400 and I think the other guys are pretty close with the 4000 nitrous stall.
Old Nov 9, 2005 | 06:43 PM
w02ramair's Avatar
What about a 4L80?
Old Nov 18, 2005 | 09:07 AM
Reject's Avatar
quick question about the GV OD for the TH400, like how dose that work, can you rachet shift that hoe? thanks for the help. i'm still tryin to learn as much as i can about the GV...since i've only just recently heard about it.
Old Nov 18, 2005 | 09:41 AM
CAT3's Avatar
Restricted User
WTF is the deal with ppl and 400 having a bigger advantage over the 350 because of "those gears" crap? They both run a 1:1 3rd gear so the rpm will be same no matter what. If you want to run bigger gears, get bigger tires to reduce the rpm but gain starting line traction, duh! The 350 will more than hold WTF you plan on throwing at it. 350 is lighter. You can add a GVOD to a 350 as well.
FWIW, I did my conversion A4 to A3 (TH350) same time as Steve, I am using an 8" ATI TC, suitable for nitrous (nice option since this bitch will be seeing the top side of a 250-300 shot soon enough). Rossler TH350 Terminator II, T-Brake, RMVB, B&M Pro Ratchet shifter, ATI Flexplate and TC, BMR XMember. Nice little setup that saves in the neighborhood of 50lbs, guesstimate, but there is a substantial difference.
GVOD is operated off a footswitch, just like the old dimmer switches mounted on the left side of the floor board. Ratchet shift, push switch, repeat!
Old Nov 18, 2005 | 01:31 PM
cablebandit's Avatar
depends on what you want/need. t350 first gear is steeper than t400. My car weighs about the same...MAYBE less with the th400 than it did with the 4l60e...dunno why. t-350 is supposed to be more efficient.....and a cheaper swap not counting the cost of the tranny.
Old Nov 18, 2005 | 02:10 PM
Bryan @ Speed Inc.'s Avatar
i have a rvmb TH400. i love it... i have a 12 bolt w/ 4.10 gears and 28" tires. i max out cruising speed aruond 67-68mph at 3,500 rpm. i have an unlocked converter in a 3,500+ lb car. if you want to stick w/ 26" tires, then go with a 3.73. but if the tires aren't an issue, keep the 4.10s and just go w/ taller tires. if the car isn't making crazy horsepower, i would definately go with the TH350. i got such a good deal on my TH400 i couldn't pass it up. but i would rather have a built TH350.
oh - and KEEP YOUR M6 CONSOLE!!! if you're getting a pro-ratchet shifter (that's what i have), or a hurst quarter stick, or b&m pro-stick. the look bad *** with the 6spd console and leather boot!
Old Nov 18, 2005 | 03:13 PM
LS1TECH Sponsor
Well said. I have a Cheetah shifter in the M6 console.
